How to make glow in the dark pebbles?
How to make glow in the dark pebbles?  (that will glow several/many days/weeks)
orksecurity7 years ago
Do you mean glow all night and/or without being exposed to light periodically?
If so, I think the only answer is battery and LED.
If not, covering pebbles with phosphorescent paint might be enough. Especially if you can point a UV lamp at them, which will not only cause them to fluoresce strongly while it's on but which will also quickly "pump them up" to their full stored-energy phosphorescent state.
This phosphorescent aquarium gravel is made of a particularly bright material and is sealed against degradation by water. There are other, cheaper substances that will do the same. In any case, it would still require continuous pumping with a black light as orksecurity said.
lemonie7 years ago
Similar to ork' you either get some radioactive paint (very doubtful) or you make LED-lit pebbles from e.g. some kind of resin. Or you paint with something fluorescent and illuminate with UV.
L
