3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make methane compressor from bicycle pump?
Methane (biogas) is a byproduct of a number of green alternatives such as a compost heap. This methane can be captured and processed usefully in small volumes. However it must be compressed to some level that will produce a controlled flow, let's say 14-20 pounds per square inch. In fact the methane could be captured and stored in a bicycle inner tube for later processing. Anybody got any thoughts on how a bicycle or small aquarium pump could be modified to compress small quantities of methane?
May 30, 2010. 9:26 AMtomohern says:
This link specifically deals with reclaiming CO2 while fermenting beer to use in force carbonating the final product in the keg, but the same method could be used to pressurize methane.
http://www.anglefire.com/cantina/carbonation/
Jun 21, 2009. 2:24 PMlemonie says:
The bicycle inner tube is too small, methane doesn't compress well and is better stored at low pressure in large tanks. What is your source of methane ? Diaphragm pumps can work well, but not the aquarium kind. L
Jun 22, 2009. 12:25 AMlemonie says:
If you're serious about this research digesters
That might be a good starting point.
L
Nov 3, 2009. 6:29 AMusertwousertwo says:
First of all, one must have a completely sealed vacuum system. The inner tube must be new and have no other gas or air in it "new" When collecting the gas all other gases and elements must be exhausted. After collecting it one could use a diaphragm pump "Vacuum Pump" to compress it in a vacuum tight container or tank. Working with methane is like working with freaon. One needs to remove all air from a tank and replace it with methane and use a high cfm vacuum pump to compress it. If the pump is hooked to a ready supply of methane and it pumps the gas from the producing tank to the holding tank it can be set to hold a certain pressure like 20psi at all times. This will help in the process of burning like a propane tank will. Propane pressures off its boiling point temp. Methane needs the pump to make the same pressures.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
