How to make voice sound like a fuzzy record?
http://www.youtube.com/watch?v=c6Np4yq0VJs there is the link to the song. The part I'm talking about is when he is singing into the megaphone.
13
answers
Answer it!
However, for a megaphone effect, you would do better to create a bandpass filter by using a low-pass set at 3 kHz and a high-pass set at 300 Hz. Then run this through some mild distortion (don't overdo it - you only want just enough to rough it up). To make it more convincing, the final effect might be a slight boost in the mid-range around 2.5 kHz, which will simulate the "honk" you get from the voice element in the horn of the megaphone.
Good luck, and enjoy grunging up your audio with yummy turntably goodness.
You could play around with the filters in Audacity?
L
I don't know what program to recommend to you for the Mac. you can find one
here
Note that if you happen to have a mid to high end Creative Labs soundcard, it probably already has the capability in its software for doing the voice modification with a little work from you. CL volume control: Audio Creation Mode
