How to program the XS3868 bluetooth audio module through arduino?
Hello, I have a few of these xs3868 bluetooth audio modules that I used in some speaker systems I built for myself, but now one of my friends wants me to build him a custom speaker with a custom bluetooth device name and passcode. So I thought, ok, I read a little about programming with the AT commands but never tried it before, so I hooked up a board to 3.3 and gnd of the arduino like I usually do to check before soldering everything, my phone connected with no problem. So next I turned off my phone's bluetooth so it wouldn't mess with the chip while programming it and connected the rx and tx pins of the board to tx and rx respectively. I also made the following adjustments in the arduino serial interface that I remember reading somewhere: No Line Ending, and 9600 baud rate. Plugged in in to the tx and rx of the arduino board with at mega chip removed and had no luck getting any response from the chip, I switched baud rate to all of the different baud rates available with no success, the only effect the chip has on the serial interface is that when the power cord slipped and I plugged in back in with rx, tx and the usb cable still connected it output a few seemingly random characters while (I'm assuming) the chip was booting up, at 115200 baud rate the characters were a "u" with two dots over it and a combination lowercase "b" and "p" (for some reason I can't copy/paste it). It only outputs these characters when one of the power wires is reconnected after being disconnected (I have a bunch of these so if I fry one it's no big deal). I tried connecting my phone again after a while and it worked, checked the wires with my multimeter and both are connected and neither is shorted to any other pins and switching rx/tx does nothing to fix the problem either. I have a usb to serial coming in the mail soon hopefully but my friend was hoping this could be finished sooner than it would arrive so any help would be greatly appreciated.
Edit: Is it possible that the module could have a rs232 interface, rather than a ttl interface? I've heard that arduino only uses ttl and that I'd need another adapter to get to rs232 since my computer doesn't have that kind of serial interface.
Picture of How to program the XS3868 bluetooth audio module through arduino?
UtkarshVerma2 months ago
I have written an instructable for the entire process:
https://www.instructables.com/id/Change-Bluetooth-HeadsetSpeakerAdapters-Name-or-Ot/
mahdam1 year ago
Hi I want pairing tow xs3686 module together?Please help me
you would probably have to have an arduino library installed
and it would probably have to have an arduino controller to store the code
and other stuff like that
KostasD101 year ago
i have a problem! my phone connects to the BT but disconnects after 4-5 seconds. any idea?
mokp1 year ago
Hi buddy ... ;)
do you know how to send a character by xs3868 ?
I have found a command (AT#ST) that can send char...
I have installed an bluetooth terminal in my phone and wrote this code :
AT#STdata ( "data" is the string that I wanna send )
but there was nothing in my phone ...
what is wrong with it ???????????
benkev1 year ago
Dear LazyH,
I am sure you have already solved this problem. However, I will publish my modest results here, because I myself spent quite a lot of time trying to work this small piece of hardware, I mean, xs3868 module based on the OVC3860 chip, and I could never find any sensible description.
I sent the AT commands from my Win 7 PC through the serial port using the USB-UART bridge based on the CP2102 chip. It is now really cheap. See, for example, "NEW CP2102 USB 2.0 to UART TTL 5PIN Module Serial Converter for Arduino YP",
http://www.ebay.com/itm/NEW-CP2102-USB-2-0-to-UART-TTL-5PIN-Module-Serial-Converter-for-Arduino-YP-/151761367424?hash=item2355aeb180:g:XBMAAOSw9N1VuJNd
I used Python, specifically IPython environment which is as convenient as Matlab, if you know it. Just key in a command and instantly get the response from the device. I used the PySerial Python module.
Here is a Python script where I gathered the AT commands I sent to xs3868 today.
# Sending AT commands via the serial port to the Blurtooth transceiver
# module xs3868 based on the OVC3860 chip.
import serial
ser = serial.Serial(port='COM5', baudrate=115200, timeout=.01)
print 'ser.isOpen() = ', ser.isOpen()
# Enter pairing
ser.write("AT#CA\r\n"); print '"AT#CA" -> ', ser.read(128)
# Cancel pairing
ser.write("AT#CB\r\n"); print '"AT#CB" -> ', ser.read(128)
# Query status
ser.write("AT#CY\r\n"); print '"AT#CY" -> ', ser.read(128)
# Reset
ser.write("AT#CZ\r\n"); print '"AT#CZ" -> ', ser.read(128)
# Query status
# Play/Pause
ser.write("AT#MA\r\n"); print '"AT#MA" -> ', ser.read(128)
# Stop
ser.write("AT#MC\r\n"); print '"AT#MC" -> ', ser.read(128)
# Connect to av source
ser.write("AT#MI\r\n"); print '"AT#MI" -> ', ser.read(128)
# Disconnect from av source
ser.write("AT#MJ\r\n"); print '"AT#MJ" -> ', ser.read(128)
# Query avrcp status
ser.write("AT#MO\r\n"); print '"AT#MO" -> ', ser.read(128)
# Start FF
ser.write("AT#MR\r\n"); print '"AT#MR" -> ', ser.read(128)
# Start Rewind
ser.write("AT#MS\r\n"); print '"AT#MS" -> ', ser.read(128)
# Stop FF/Rewind
ser.write("AT#MT\r\n"); print '"AT#MT" -> ', ser.read(128)
# Query A2DP Status
ser.write("AT#MV\r\n"); print '"AT#MV" -> ', ser.read(128)
# Decrease Volume
ser.write("AT#VD\r\n"); print '"AT#VD" -> ', ser.read(128)
# Increase Volume
ser.write("AT#VU\r\n"); print '"AT#VU" -> ', ser.read(128)
# Read a byte from memory
ser.write("AT#MX08001AC4\r\n"); print '"AT#MX08001AC4" -> ', ser.read(128)
# Print 64 bytes of memory starting from 0x08000000
for a in xrange(64):
addr = 0x08000000 + a
ser.write("AT#MX"+hex(addr)+"\r\n")
r = ser.read(128)
i = r.find('MEM:') # Index of first letter of "MEM:" in r
r = r[i+4:] # Cut away up to end of 'MEM:'
i = r.find('\r') # Index of first letter "\r" in r
# In hexadecimal, 2 digits with leading zero:
print '%08x: %02x ' % (addr, int(r[:i], base=16))
ser.close()
If you have any questions, please do not hesitate to ask me.
benkev benkev1 year ago
Here is the Python script output:
ser.isOpen()
"AT#CA" ->
OK
"AT#CB" ->
OK
IJ2
"AT#CY" ->
MG1
OK
"AT#CZ" ->
MF01
OK
"AT#CY" ->
MG1
OK
"AT#MA" ->
OK
II
"AT#MC" ->
OK
"AT#MI" ->
OK
"AT#MJ" ->
OK
"AT#MO" ->
ML1
OK
"AT#MR" ->
OK
"AT#MS" ->
OK
"AT#MT" ->
OK
"AT#MV" ->
MU2
OK
"AT#VD" ->
OK
VOL14
"AT#VU" ->
OK
VOL15
"AT#MX08001AC
MEM:0
OK
08000000: 18
08000001: 18
08000002: 18
08000003: 18
08000004: 18
08000005: 18
08000006: 18
08000007: 18
08000008: 18
08000009: 18
0800000a: 18
0800000b: 18
0800000c: 18
0800000d: 18
0800000e: 18
0800000f: 18
08000010: f0
08000011: f0
08000012: f0
08000013: f0
08000014: f0
08000015: f0
08000016: f0
08000017: f0
08000018: f0
08000019: f0
0800001a: f0
0800001b: f0
0800001c: f0
0800001d: f0
0800001e: f0
0800001f: f0
08000020: 9f
08000021: 9f
08000022: 9f
08000023: 9f
08000024: 9f
08000025: 9f
08000026: 9f
08000027: 9f
08000028: 9f
08000029: 9f
0800002a: 9f
0800002b: 9f
0800002c: 9f
0800002d: 9f
0800002e: 9f
0800002f: 9f
08000030: e5
08000031: e5
08000032: e5
08000033: e5
08000034: e5
08000035: e5
08000036: e5
08000037: e5
08000038: e5
08000039: e5
0800003a: e5
0800003b: e5
0800003c: e5
0800003d: e5
0800003e: e5
0800003f: e5
mattts2 years ago
Hey I am also a little curious whether you where able to change the password as well as the name?
benkev mattts1 year ago
I tried the commands AT#MM and AT#MN -- no, they do nor work:
import serial
ser.write("AT#MM\r\n"); print '"AT#MM" -> ', ser.read(128)
"AT#MM" ->
ERR2
ser.write("AT#MN\r\n"); print '"AT#MN" -> ', ser.read(128)
"AT#MN" ->
ERR2
I read somewhere it is possible but only until the device is hooked up to thr battery or power supply. After it has been disconnected and connected again these changed are lost. The commands are:
查看用户名和密码
AT#MM /* Get the BT device name */
AT#MN /* Get the BT device pin code */
修改用户名和密码
AT#MMXX /* Set the BT device name */
AT#MNYY /* Set the BT device pin code */
返回
This is the source Chinese pdf:
http://wenku.baidu.com/view/92338ad484254b35eefd34...
achand82 years ago
Try connecting Tx-Tx and Rx-Rx. BTW use a level shifter. There is some problem with Tx Rx pins on Arduino Uno. I did the same on my ESP8266 and Tx-Tx connection works. But when I was using hardware serial with atmega328 plugged in with HC05 module, Tx-Rx connection worked. Just put a voltage divider on Rx pin of arduino Uno connect Tx-Tx Rx-Rx and see if it works
LazyH (author)  achand82 years ago
neither orientation seemed to work. What kind of effect does the voltage divider have on the signal? I don't have much experience with this kind of thing so I'm curious about how you would do this, is it a component you place in the path of the signal between RX pin on arduino and the corresponding pin on the Bluetooth module or is there a setting on the board for that. Sorry, you can probably tell how little I know about this kind of thing.
achand8 LazyH2 years ago
Try this,Upload a blank sketch to arduino and then connect a 1k in series with 2k resistor from arduino rx pin to ground. then connect the 1k 2k junction to rx of the module, connect tx to tx directly. Now open serial monitor, choose settings BOTH NL & CR and try different baud rates, send AT and it should return OK
Ok, between kids and work, i finally got the time to throw together a voltage divider, I'll post some pics later once I find my camera. I'll post an instructable once i finish setting it all up with a few simple sketches too for anyone interested. Thanks for all your help.
if it needs 3.3v input then that would explain why the board started burning after a while trying to send it commands at 5 volts. Sorry it took a while to get back to you, I get internet from my phone and my phone was broken for a while.
Oh, so that's what level shifting is, I get it now, since 3.3v is ~=5v(2/3) you put the signal output 2/3 up from what the signal path sees as 3 equal value resistors. I get it now, thanks. Now to give it a try, that video posted a couple comments up said something similar, with the same circuit.
SineirM2 years ago
this video has the correct connections, in time 1:47
using the serial in different pins TX / RX Arduino (10 and 11 example)
commands at: http://labdegaragem.com/forum/topics/hc-06-comando...
I connected to the same video, loaded the software and sent commands smoothly. I could not receive data. Probably do voltage divider as similar HC05
boards are different (v1.2 X v2.0)
Hi,
Nice post. Do you have some news or updates ?
I 'm trying to do exactly the same.
It was for a friend birthday and i started to build diffrents king of speaker's.
The bithday was in November and he is still waiting for it ;-)
I couldn't change the name on the BT controleur.
I tried with an HC-05 & 06 i could change the name but couldn't use it as a Bluetooth audio receiver.
I also bought a BT usb audio receiver stick with rt/tx but couldn't talk to it.
I don't have a lot of knowledge and experience at this anyway and got an Arduino Uno fiew month ago.
Did you find any solutions or alternatives ?
Did you aske the resseller if they know how to do that ?
Than
LazyH (author)  jeanluc.geronimi.12 years ago
unfortunately the extra hardware I'm waiting for that would allow me to use rs232 to program it got lost in the mail and I have no other ways to set this up right now. I'll post an update as soon as it gets here and I can try it out, just hope it won't be too much longer.
In my mind its better to be a little late than do something half @$$, I hope your friend enjoys them when you finish those speakers. I'd love to hear more about your speakers, are they going to be a smaller portable set or larger Bluetooth controlled system? I'm mostly going to use the hivi b1s 1 inch speaker for mine, lithium batteries to power the amp and Bluetooth and a little charging module to power the whole thing from USB.
Hard to say. The datasheet is in Mandarin. Its HIGHLY unlikely to be anything but 3v3 logic - NOT TTL, which is 5V. You'll need to create RS232 for your USB interface, unless you are using one of FTDI's interface cables, with 3v3 logic out.
LazyH (author)  steveastrouk2 years ago
Ok, would a max3232 work for that? I figured I'd order one when I got my serial adapter. Would it also work through the arduino ide still? That's the only way I know to program a serial device.
All you need is a terminal emulator, the one in the Arduino will work, but there are many others.
Yeah, the 3232 is idea.
