How to read values on preset potentiometer?
Recently my multimeter died in a coilgun experiment. now i need to make some 555 circuits out of scraps. when i need some preset pot. i don't know their values. for e.g a preset pot has a reading of 103 on it(not a capacitor). How can i know its reading. is there anything like capacitor readings in it.
That 103 is a 10K, 10 + 3 zeros.
Manoj BR1 year ago
There are some spelling mistakes. Pardon me for that.
Manoj BR1 year ago
Reading a pot is just similar to that of reading a ceramic capacitor.
If a pot is named XXX.
Then the value of the pit can be calculated easily just c retain the first 2 numbers as it is and multiply it by 10 to the power of 3rd number.
i.e, XX * 10^X ohms
For example 103
10 * 10^3=10Kohms
474
47 * 10^4= 470Kohms.
103 is 10k.
NachoMahma7 years ago
.  Trying to do electrical work without a multimeter is a lot like trying to do carpentry without a hammer. You should be able to find a "good enough" meter for $5-15 (or your local equivalent).
.  What exactly is a "preset pot"? Are you talking about the resistance of the potentiometer's resistive element or the resistance between the wiper and one leg? If the resistive element, then it should be marked on the pot somewhere. (Wild guess: 103 might indicate 103, or 1K, ohms.) If wiper-to-leg, you will need some instrument/circuit to get a measurement.
.  If you are talking about a fixed resistor, there should be color bands that you can interpret. Search for "resistor color code".
*insert graphic of a +1 here*
that 1k seems correct, I believe it's 1.0 x 10^3, = 1000
so 991 would be 9.9 * 10^1 = 99 ohms
someone correct me if I'm wrong.
