How to recharge these batteries?
4
answers
Answer it!
If you use a circuit like the one I attach, and set the resistor you need =1.22/ charging current, you'd be good to go - provided the current is less than 1 A or so.
I hesitate to suggest another way, because they rely on being able to measure battery temperature to detect when the battery is charged. Charging at 1/10 C is a safe method, and you can leave the batteries on charge occasionally without harming them. Faster rates are actively dangerous, without proper control.
Steve
Your drill will run on 12 volts but not very well, just barely.
Just get a new charger and battery. If its to expensive then get a new drill. Sad to say but sometimes a new drill kit will cost less than replacement batteries.
Thanks for the answers!
