How to replace a potentiometer?
6
answers
Answer it!
If that's the case, glue any parts of the knob back in place with CA (super krazy etc) glue. To reattach it to the pot, it should be a friction fit, have a screw in the side, or be glued on. I recommend monster glue. That stuff sticks to anything.
Knurled, detent, or slotted
friction fit, or with a screw to hold it in?
With that information you can order new knobs...
the value (ie. 10k, 100k, 500k)
the type (linear or logarithmic)
the shaft size (ie. 1/4")
shaft length (ie. 1/2")
shaft type (ie. smooth, knurled)
the mounting hole size (ie. 3/8")
If you're not comfortable doing this yourself, a decent musical instruments store should be able to do it for you.
All that said, the Pot is one of the few things in those that you can still get and are still made the same way. If you can get the specs off of it and a rough guesstiment of the year made, you're probably better off eBay-ing yourself a replacement pot.
Finally, if you don't feel like doing that, I'm going to assume that you sheared off the shaft on the pot. To fix this you'll need to pull out the pot and superglue the shaft back on. You will need to use an extraordinarily tiny amount of CA to do this, and not allow any of it to run down the shaft (hint: do the gluing upside-down). Make sure the two part go together in one motion and don't move them while the CA sets.
