3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to seal photos on wood?
Can anyone recommend a sealant suitable for sealing photos stuck to wood? I want it to be durable and wipable (it's for a food tray). It wouldn't have to seal the wood around the photo, just on top of an A3 photo.
I *would* go down to the local DIY superstore and ask there, but a lot of their staff are monkeys, I'm sure you guys could give me a better answer :p
Dec 11, 2009. 3:07 AMNinzerbean says:
 I have done this a lot actually, I always use a water based polyurethane. Sand lightly between coats with a 250 or higher grit sandpaper. I use high gloss (stir gently enough not to create bubbles, but well) because I like shiny things.
Dec 11, 2009. 12:39 PMNinzerbean says:
Thanks J! BTW the sandpaper will scare you into thinking you have wrecked the project but your next coat will go on so smooth you won't believe it and then it becomes addicting to see how many coats you can put on building up that gorgeous finnish.
Dec 11, 2009. 12:47 PMNinzerbean says:
No, you want the stuff in a can, but not a spray can, use a brush made for acrylic paint, good and wide. At first you will see brush strokes but they will flatten out, even easier is to use a sponge bush, a 3 or 4 inch wide one. One more thing, Between coats put your brush into a ziplock baggie and put it in the fridge, that way you won't have to clean between coats. The fridge is good for a day or more even.
Dec 11, 2009. 7:49 AMDELETED_GuardianFox says:
There's a line of products called Mod Podge which has been pretty much the standard for doing this for forty-plus years.
The flavor you want is Hardcoat Mod Podge, it even says it's perfect for food trays.
For info:
http://www.plaidonline.com/apmp.asp
To buy it in your area?  Visit a hardware store, a paint store, a craft supply store, or even Walmart.  One of those places will have it.
Dec 11, 2009. 6:19 PMDELETED_GuardianFox says:
Very sorry to hear that!  Hope you find what you're looking for!
Dec 11, 2009. 9:15 AMseandogue says:
glue them down to the wood, then overspray with several coats of clear acrylic or polyurethane.
Dec 11, 2009. 9:11 AMAngryRedhead says:
Depending on the tray and what you want exactly, epoxy might do the job very nicely.  Look up how to make epoxy resin jewelry, and you'll get the idea.
Dec 11, 2009. 5:27 AMorksecurity says:
Websearch "decoupage"?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
