3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to secure metal shaft into bearing with larger ID?
A question for mechanical gurus :)
I'm building motorized Igus camera slider based on Kokomonstrum design.
I have a shaft that's 1/4" OD that needs to go inside bearing block that has bearing with ID of 5/16". I know I need some kind of bushing, but ones I bought at McMaster don't fit bearing opening (even tho they are 5/16 OD). What are my options? Tape wrapped around shaft? Epoxy? Can't think of anything else :(
Nov 18, 2011. 11:04 AMiceng says:
Heat the bearing in boiling water ( in a plastic bag if iron ) and
put the bushing in the freezer then try fitting it together.
A
Nov 18, 2011. 11:02 AMsteveastrouk says:
I don't see why a 5/16 bush doesn't fit the hole ? Have you measured them with a vernier ? What is the bush made of ?
Nov 20, 2011. 6:11 AMsteveastrouk says:
Being plastic, I'm going to suggest its designed to be knocked in, so its a bit bigger than you'd expect.
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
