How to stop a servo using conditional if?
I'm using an Arduino Uno, Ultrasonic sensor (HC-SR04) a Servo motor (SG90 Tower Pro).
I would like to rotate the servo continuously from 0 to 180 and back to 0.
I would like to stop the servo whenever the ultrasonic sensor detects an object  at a distance of 40 cm or less.
I know how to rotate the servo and how to detect an object using the ultrasonic sensor, but I couldn't combine the two.
Can you kindly help me on how to do so?
rickharris9 days ago
You have several potential issues. Your Arduino only does one thing at a time so if it is moving the servo it isn't listening to the US module.
You need to do this in the form:
Start
Move a little, send receive
If no signal then if servo not at end loop to start
This will scan, check, scan, check - so if you detect an object you can jump from the scan routine to the object avoidance.
The HC-SR04 module needs to be triggered and then a check for an object made and the distance calculated then you can decide what to do.
In actual fact in all the HC-SR04 sensor robots I have built the detection field is wide enough not to bother scanning - You can do as well just by looking forward.
Trust me
Reading and doing the following WILL help you a lot
https://www.instructables.com/id/Starting-programm...
Something like
start
Move servo 10 deg
trigger HC-SR04
Check for object
if object <100 mm then avoid
If not go to start
avoid:
Turn right 20 deg
goto start
Something like this, in pseudocode, will work I thinl
while TRUE
{ check range
if (range >40 cm) servo position=servo position +increment
if servo position>=180 then increment =-1 else if (servoposition<=0) increment =+1
move servo (servo position)
iceng10 days ago
First take the free Arduino class and learn software it will be rewarding
https://www.instructables.com/class/Arduino-Class/
You will be glad to answer your own question !
