loading
How to stop glare on a wireless camera?
where is the glare from why dose it  come from can anyone help?
Re-design6 years ago
You stop lens "flare" in a wireless camera the same way you stop it in a wired camera.
Glare or "flare" is caused when a bright light reflects off the surfaces of the inside of the lens.  It's caused by a light that is too bright compared to the rest of the scene.  It can be controlled by using a lens hood or aiming to get the light away from the view of the camera.  It can even be a light source that is not seen in the viewfinder.
See this article.
alspad (author)  Re-design6 years ago
its not the camera lens it is the receiver antenna for the camera.
I don't see how a receiver antenna can cause glare in the camera unless the antenna is in front of the lens. If so then move the antenna.
alspad (author) 6 years ago
well its not the sun it's the reviver antenna what is not capable of a long distance
aelias366 years ago
You can see why lens flare occurs from the picture below. To fix the problem, you're going to need a lens hood. It blocks all light rays from entering from outside the actual viewing area.
