How to write code for an Arduino with the Arduino motor shield.
What would the code for an Arduino, with the Arduino motorsheild, look like to run a 6V 300 mA DC motor? I want to stop and start the motor at a certain frequency (I don't have to reverse the direction of the motor). For example at every 5 minute interval I want it to run the motor for 2 minutes and stop it for 3 minutes. Any help or advice is appreciated thanks.
The motor shield just expects a pin to go high or low to enable the output to the motor (if I recall).
Handling the timing aspect in code should be very easy; There are 3 easy methods I can think of to handle the timing;
assuming your sketch is already set up with something like motorPin = 6; pinmode(motorPin,OUTPUT);
you should be able to set in loop()
digitalWrite(motorPin,HIGH); //turn motor on delay(500); //wait digitalWrite(motorPin,LOW); //turn motor off delay(500); //wait
(this is the example from 'blink' essentially).
The EASIEST method would be to change the delay values to the 120 seconds (120000ms) on, and 180seconds off (180000ms).
You can feed delay(); an unsigned long value, so there is no fear of sending too large a number in this instance.
This method is BRUTALLY inefficient, because during the delay(), you can do NOTHING else with the processor. This is fine so long as you ONLY want to switch the motor on and off, no input/output.
A more efficient method, but a bit more convoluted is to use the millis(); function. calling millis(); returns the number of milliseconds since the arduino started up. Knowing that time value means you can set a timecode of when you want the function to fire, and keep checking that millis value (along with all your other code you may be doing).
might not compile - I'm just typing this, so excuse typos.
//Written by Frollard May 2012 //Should toggle a pin on and off without using the delay(); command //CC NC SA
void setup() { int motorPin = 8; //define which pin to use pinmode(motorPin,OUTPUT); //set up motor pin boolean motorStatus = FALSE; //motor off digitalWrite(motorPin,motorStatus); //turn motor off unsigned long onDuration = 120000; //how many ms to stay on unsigned long offDuration = 180000; //how many ms to stay off unsigned long NextToggle = millis() + offDuration; //next time we do anything is in 180000 ms from power on } //end setup
void loop() { if (millis() > NextToggle) //check to see if current time exceeds the timestamp we set. {//time has elapsed MotorToggle(); //changes the motor and updates the timer } else { //time hasn't elapsed //don't care, don't do anything } //end if //*************here is where all the other code you could want would go
//*************this gets looped regardless of whether we are waiting or not! } //end loop
void motorToggle(){ motorStatus = !motorStatus; //toggle if motor was on/off digitalwrite(motorPin,motorStatus); //set the motor to whatever if (motorStatus) {//motor is turned on NextToggle = millis() + onDuration; } else { //motor is turned off NextToggle = millis() + offDuration; } //end if }//end motortoggle
So, I initially couldn't find the motorshield pinout; I looked a bit closer, and found http://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/ which explains all the pinouts Function Channel A Channel B Direction Digital 12 Digital 13 Speed (PWM) Digital 3 Digital 11 Brake Digital 9 Digital 8 Current Sensing Analog 0 Analog 1
"In order to get the board to do anything, you need to initialize the motor channel by toggling three parameters:
First you need to set the motor direction (polarity of the power supply) by setting it either HIGH or LOW. Then you need to disengage the brake pin for the motor channel by setting it to LOW. Finally, to get the motor to start moving, you need to set the speed by sending a PWM command (analogWrite) to the appropriate pin.
If you do not do all three of these things, the motor will not turn on."
So, we need
MotorADirection MotorABrake MotorASpeed
declared...
resulting in:
void setup() { int motorADirectionPin = 12; //Boolean, high = forward int motorABrakePin = 9; //boolean, low = allow to run int motorASpeedPin = 3; //pwm output for speed, 0-1023 pinmode(motorADirectionPin,OUTPUT); //set up motor pin pinmode(motorABrakePin,OUTPUT); //set up motor pin pinmode(motorADirectionPin,OUTPUT); //set up motor pin
boolean motorStatus = FALSE; //motor off analogWrite(motorASpeedPin,0); //turn motor off (speed = 0) digitalWrite(motorADirectionPin,HIGH); //set motor to forward direction digitalWrite(motorABrakePin,LOW); //disable brake, leave it that way. unsigned long onDuration = 120000; //how many ms to stay on unsigned long offDuration = 180000; //how many ms to stay off unsigned long NextToggle = millis() + offDuration; //next time we do anything is in 180000 ms from power on } //end setup
void motorToggle(){ motorStatus = !motorStatus; //toggle if motor was on/off if (motorStatus) {//motor is turned on analogWrite(motorASpeedPin,1023); //set the motor to ON 1023 NextToggle = millis() + onDuration; } else { //motor is turned off analogWrite(motorASpeedPin,0); //set the motor to OFF 0 NextToggle = millis() + offDuration; } //end if
...the analogwrite values should be 255 and 0, not 1023 and 0 -- analog write only takes a number from 0-255. It works here because 1023 is all 1's in binary so its tricked into thinking it has the right number.
remember, don't forget to mark answered if this helps :)
Bio:Despite my date joined I've been here on instructables back when the site was new. I left for awhile and when I returned the site was drastically different but more popular. I'm a skillful outdoorsman...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
motorPin = 6;
delay(500); //wait
delay(500); //wait
//CC NC SA
void setup()
} //end setup
void loop()
{//time has elapsed
else
} //end if
} //end loop
void motorToggle(){
if (motorStatus)
else
} //end if
}//end motortoggle
So, we need
MotorADirection
MotorABrake
MotorASpeed
declared...
resulting in:
//CC NC SA
void setup()
} //end setup
void loop()
{//time has elapsed
else
} //end if
} //end loop
void motorToggle(){
if (motorStatus)
else
} //end if
}//end motorToggle
in motorToggle()
