Compress the spring into a piece of pipe or tubing that is the right length. Hold the spring inside with a hinge that closes the end of the tube. Release the hinge and the spring will "jump up".
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Is this in reference to the blue mechanical spring found in fischertechnik?
"Watch out kid or you'll put your eye out!"
