3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How would be the best, easiest, cheapest way to make two tubes adjustable?
I need to get two small tubes (one slightly bigger then the other) and to have each hold a lens and be adjustable (rotationally)? That is, they rotate along the axis of the tube  (as if holding the two lens near one another and turning one).  I have several options and am not able to purchase anything at the moment (or  I'd get some small plastic piping that fit fairly well together).
Any ideas?
Aug 22, 2011. 10:15 PMiceng says:
I've used paper tubes for optic lens holding.
A shipping store if you have them in the east will carry some immediate
tubes. . . . . . .   A
Aug 23, 2011. 5:18 PMcaarntedd says:
I have found when trying to fit tubes inside other tubes, metric to imperial or something else unusual, that mixing and matching works well. Try a combination of plumbing and electrical conduit. There sizes are measured in different ways, and I have used the plumbing/electrical combination a number of times to make slip joints. Also look at normal plumbing pipe combined with garden watering stuff. Combining tubing sourced from different industries provides a much wider selection of combinations/connections/fittings than sticking to just one type.
Aug 24, 2011. 6:15 PMcaarntedd says:
Remember my "How long have you waited for your wife?" posting in the forums?
Aug 23, 2011. 9:59 PMiceng says:
See the paper tubes I used for ¾" lenses.
And how to fix one lens on right by pressing two segments to hold
using magic tape to fit tight.
While on left a slide tube focus  with green segments holding objective lens.
A
Aug 23, 2011. 1:07 PMseandogue says:
(removed by author or community request)
Aug 23, 2011. 9:23 PMseandogue says:
Aug 23, 2011. 2:21 PMdiyoutdoorsman says:
With that diameter, have you considered aluminum or plastic cigar tubes?
Aug 23, 2011. 5:06 PMdiyoutdoorsman says:
Another option would be PVC or CPVC water pipe. In plumbing circles, pipe measurements are ID and tubing is OD. A 3/4" PVC water pipe would have an inside diameter that should fit your lens. You could place caps on the ends of 1" PVC pipe and bore through the center and insert the 3/4" pipe through the holes. The caps would serve as bushings to allow the inner pipe to rotate on an even axis. You could also mark the end of the protruding pipe and index the cap to determine the amount of rotation. Alternately, if the lenses are the same size, you could use two pieces of 3/4" pipe and a coupling in the middle. The coupling could be indexed to indicate the travel.
Aug 23, 2011. 1:53 PMlemonie says:
What are these reactants and products?
L
Aug 22, 2011. 8:43 PMCameronSS says:
Roll your own, but only if that's legal in your state.
Aug 23, 2011. 9:12 AMPKM says:
What CameronSS said, roll them out of paper and white glue. You could get one PVC pipe and roll the other to fit it, or roll both (potentially even using the smaller as the form for the bigger).
If they both need the strength of PVC or something sturdier than paper, try to find two sizes where the smaller fits inside the larger with a smallish gap between and build up the outside by gluing on layers of something until it's a sliding fit.
As a child I had a balloon pump- two cardboard tubes that made a sliding fit with a nozzle and one-way valve on one end, so it worked a little like a simple bicycle pump. If you can find one of these in a toy shop it could work.
Aug 23, 2011. 6:55 AMRe-design says:
I built a telescope a few years ago and used plumbing pipe from Home Depot. I found two pieces that had about 1/8" clearance then used the fuzzy stuff from stick on velcro to make a friction fit. Still working great.
Aug 23, 2011. 4:54 AMrimar2000 says:
Like CameronSS, I suggest you roll your own. I think that is the only way to have that you need. Think to use aluminum from soda cans, it is a very good material: enough workable, enough hard, free access, etc. I ised it for optics.
Paper maybe will work for you. After made the tube with some turns and vinylic glue, you can permeate it with vernice or so to give it more stiffness.
Aug 23, 2011. 1:55 AMsteveastrouk says:
In brass, or stainless steel, try K+M metals in Chicago - or the local model shop. They sell 12" lengths of telescopic tube, in diameters up to 1"
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
