loading
How would one build an amplified (electronic) megaphone?
Sup guys. Im trying to start buildign an electronic megaphone, but i dont know where to ger started. I've looked online enough on building and amp, but  dont know if using a microphone requires a preamp on it. So far, i have a plastic cone for the physical part, and a 4 ohm 10W mid-tweet speaker to project the sound. All i need is to know if a pocket amp is sufficient to amp a passive mic loud enough over a crowd. I need need any superb audio quality, just something that you can actually hear what is being said. I would appreciate any plans and help. TY
rickharris5 years ago
Microphone - Amplifier (lots around if you search for audio amplifier circuit) - Lou8d speaker - Traffic cone cut down to a suitable size.
SteamOh (author)  rickharris5 years ago
but would a simple lm386 build be enough to amplify to the loudness i want?
I don't know because I have no idea how loud you want it to be!.
It will be reasonable I guess - a lot depends on your speaker/input level. Experimentation is the key here the LM386 isn't expensive and your going to get a lot of experience that may lead to to another audio amplifier that is better/different.
have fun.
Depends on the mike ! Whatcha got ?
SteamOh (author)  steveastrouk5 years ago
Oh.... never thought of that. Dont have one yet :b. Any advice on chossing one would be greatly appreciated too. Thank you!
Try it with a cheap headset mic. They're usually Electret types. Tie one end of the mic to +supply VIA a 10K resistor or something, and take the signal into your amp through a capacitor
Would a simple lm386 amp build be enough though? The best lm386 i can find has a 1W max output
If you have a good horn shape, you'll be amazed how little power it takes to be offensive....
Steve
