3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Human urine and beer are superficially similar...?
Both are kinda yellow-colored. Both have bubbles, to the extent that if you shake up either you can get a good head of foam on them.  Both are mostly water.
I'm convinced that there must be a scientific, logical, concrete, fundamental, causal explanation for this similarity, and one of you punks and/or eggheads is going to tell me what it is. He, she, or it, (i.e man, woman, or robot) who best answers this question for me, will be bestowed with the honor of *BEST ANSWER* for this question.
Jan 9, 2010. 2:36 AMlemonie says:
The yellow colour in urine is a derivative of haem - see here what makes beer golden is usually malt.
Foam on beer is often a complicated thing but it involves proteins, there you've got a similarity, but probably not the same proteins.
Mostly water, so mostly the same...
L
Jan 12, 2010. 8:22 PMorksecurity says:
Remind me never to accept a dinner invitation from you.
Jan 9, 2010. 2:13 AMKiteman says:
You're not thinking of beer, you're thinking of lager.
The only difference between lager and urine is the alcohol content.
Jan 9, 2010. 4:04 PMRe-design says:
I like making my own beer.  I made wine once and it wasn't really very drinkable.  But I've had pretty good luck with beer.
Jan 9, 2010. 6:56 AMfrollard says:
You stole my answer - 5 hours before I wrote it!
Jan 9, 2010. 6:01 AMpaganwonder says:
+3!!
Jan 9, 2010. 4:59 AMRavingMadStudios says:
+1
Jan 9, 2010. 5:55 AMstephenniall says:
+2!
Jan 9, 2010. 4:25 AMkeydogstony says:
That's a good one. :)
Not a fan of Lager beer, ah?
Jan 9, 2010. 5:03 AMJayefuu says:
You wouldn't be either if you'd had ale. It has flavour. :)
Jan 9, 2010. 6:55 AMfrollard says:
Similarities - both are a bunch of stuff dissolved in water - be it salts, or alcohol and other goodness.  Anything dissolved in water will change its physical properties - density, surface tension (makes head of foam), colour, etc.
Answer:  Most all american beer is piss.
Lager like the one pictured often resembles piss.
BEER is served warmer and nearly flat - often heavier, darker, and much more flavourful.
Bust out some import brew and start enjoying the beer experience!
Jan 9, 2010. 9:30 AMRavingMadStudios says:
Good advice, but even better, go pick up a few inexpensive supplies and brew your own. Homebrewed beer is a joyous thing, and you get to make exactly what you like. Just remember - lager yeast is evil, and all hops are not created equal.
Jan 9, 2010. 10:04 AMfrollard says:
Indeed - I grew up (ages about 6-15) with my dad brewing at home.  I we never much of a drinker...obviously - but it was a fun family project to make all sorts of beer and spirits.  Trouble with homemade beer is you have 3 options:
Unfiltered and carbonated - good til just before the last drop, where the goo in the bottle makes you want to throw up :(
Filtered and flat :(
Filtered and recarbonated with relatively expensive/time consuming rig.
Jan 9, 2010. 2:08 PMRavingMadStudios says:
I always went with the unfiltered & carbonated option. The trick is to never drink it straight out of the bottle. Pouring carefully into a glass and leaving about a half-inch in the bottle gets rid of the nasty goo problem.
The other two options are not options at all, IMHO.
Jan 9, 2010. 6:45 AMRe-design says:
I would like to suggest that if You can't tell the difference then maybe you had too much of one and are about to produce too much of the other.
Jan 9, 2010. 1:30 AMAndyGadget says:
As a long standing (and occasionally lying down) British beer drinker, I will give you Joshu's answer when asked if a dog has Bhudda nature . . . "MU!"  It 'unasks' the question because the question is not a question at all.
Beer, to me, is anything from the lightest golden brown, through amber (possibly with a reddish tinge) to dark, dark, dark brown, and when a sip is taken it should overwhelm the senses with the aroma of hops and malt. It should conjure up visions of drying sheds, malt shovelling and barley fields rippling in the summer breeze.
Some breweries catering for the less discerning palate in the UK seem to have a problem realising this.  In the US, this sort of drink appears to be a way of life.
I have not tasted urine, but as the common utterance goes when referring to a sub-standard brewed beverage of this nature goes, I will just say "This beer tastes like piss!"
Jan 9, 2010. 2:41 AMlemonie says:
I would think that breweries catering for the less discerning palate have no problem at all - the objective is to make the stuff go down the neck easily and shift volumes. They'll know about flavour in order to avoid having too much of anything challenging, and if you chill it it gets blander still.
L
Jan 9, 2010. 6:31 AMBigev says:
Are you suggesting.... warm beer? Granted, I've not tried beer either way so who am I to judge.
Jan 9, 2010. 11:29 AMsteveastrouk says:
Its an old calumy against our (English)  beer drinking. Beer is NEVER served "warm", it IS served at UK cellar temperature, which I'd guess at about 10-12°C.
Like Lemonie says, its never served CHILLED.
Jan 9, 2010. 8:44 AMlemonie says:
The taste experience Andy' is referring to comes with not-cold beer. Serving beer chilled or "extra-cold" dampens the flavour such that pretty much anyone can drink it (e.g. Guinness), and that is the point.
Ice-cold suds on a hot day are not necessarily the same thing though.
L
Jan 9, 2010. 9:26 AMRavingMadStudios says:
Very true. Beer (not lager) should be served cool, but not ice-cold. Serving too warm can release nasty flavors we don't want, but a decent beer can stand up to regular room temp (72F) just fine. I prefer mine a few degrees cooler than room temp, but that's personal preference, not because the beer requires it.
The only legitimate use for lager is to serve it ice-cold with a bit of lime juice added in, on a very very hot day, when you've been doing hard labor in the sun. Then, and only then, is lager a pleasant experience. Still, lager should never be mistaken for beer.
Jan 9, 2010. 10:18 AMlemonie says:
They are different things, what I object to is super-chilling stuff because people won't drink it otherwise. It's energy-expensive and relies upon marketing to persuade people they'll look good drinking it, but they won't have to hold their noses...
L
Jan 9, 2010. 5:34 AMRavingMadStudios says:
I'm just very impressed that you went to the trouble of peeing in a salsa jar to get a pic for this question. And also, you're apparently very well hydrated.
Jan 9, 2010. 6:32 AMBigev says:
It appears as if he put dish soap in water to get foam. That's a tricky state of hydration to maintain.
Jan 9, 2010. 9:16 AMRavingMadStudios says:
I really hope you're mistaken about the dish soap. Does that make me a bad person?
Jan 9, 2010. 8:34 AMBurf says:
Yes, superficially, urine and beer are similar. Why is that? Let's break the word “superfiaially” down into its constituent parts:
First there is the word “super”, meaning; great or way above average or really hot stuff (as in “she's really hot stuff”.) So you could use these meanings instead of saying super. You could say “great-ficially, or way above average-ficially or she's really hot stuff-ficially, but super is much shorter and we're lazy by nature, and its easier to type “superficially”.
And you can also preface many other words with the “super” prefix. For example, Superman, or super-duper, or supersalad. Can you imagine how cumbersome it would be to try and say, “Man that is way above average-califragilisticexpialidocious," instead of “supercalifragilisticexpialidocious.” Think about it, supercalifragilisticexpialidocious. Even though the sound of it is something quite atrocious, if you say it loud enough,you'll never sound precocious.
Now on to “ficially.” Ficially, is a word that hardly ever gets used alone. Consider, for example, “oficially.” There it is again, ficially with another word in front. Well, a letter in this case, but it can be a word if you want it to be, like, “O, look!”
So to sum it up, I will almost quote Douglas Adams here,However, no one knows quite why ...but a cupful of urine ...is... almost, but not quite, entirely unlike ...beer.”
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
