I WANT TO JOIN TWO METAL COMPONENT WITHOUT NOT AND BOLT. I WANT TO JOIN THEM BY SOME SOLUTION?
TWO METAL SURFACES ARE ALUMINIUM AND STAINLESS STEEL. I WANI TO JOIN THEM WITHIN 1-2 MIN. OR SOLUTION CAN BE SOLIDIFY BY HEATING.IS THERE AY SOLUTION WHICH SOLIDIFY QUICKLY AFTER HEATING??
mrmerino4 years ago
SCREAMING IS FUN
iceng4 years ago
A shaped explosion will join most differing metals into a gas tight joint !
I worked on a British Stainless steel project once where they were making beer barrels From a sheet of Stainless steel by using explosives!
Once the project was proven they were going to go over to hydraulic power. Exciting stuff.
FYI... When you type in all caps it is perceived as yelling. So there is no need to yell at us. ;)
Brazing will work
There are also special solders that will work.
You don't say how strong the bond needs to be. Wax would "work"
ADITYA1991 (author)  steveastrouk4 years ago
I THINK LOCATITE WOULD BE BETTER??
WWC4 years ago
Loctite
ADITYA1991 (author)  WWC4 years ago
OK I WILL LOOK FOR THAT
rickharris4 years ago
Rivet,
Glue
weld (tricky)
Whip with cord or wire
Fold the edges of the aluminium over the steel.
By the way your likely to get corrosion between the steel and aluminium.
ADITYA1991 (author)  rickharris4 years ago
THANKS FOR UR SUGGESTION..
