I cant run power to my shed so I want to know can I use the solar cells from the outdoor lights to make a solar panel?
5
answers
Answer it!
Have a look at this retail shed light.... http://www.graysonline.com/Lot.aspx?id=3692971 ...
You could make better but it'll probably cost more.
Don't be led down the garden light path (pardon the pun), buy some decent cells, a 4 amphour 12volt battery, a 6 watt controller and make a top notch unit for yourself.
The cells in the garden lights are sealed in a polyurethane laminate which loses it's clarity after 2 or 3 years, reducing it's efficiency.
If you're determined to do a DIY, which is a good thing, then have a look at the instructables I've posted on panel building and My Solar Setup.
http://www.instructables.com/id/DIY-Solar-Setup/
There might be something there you can use.
All the best with it.
Rob.
