I couldn't resist posting this, what do you think about this description?
Description:
  • High quality, high effective and high stability.
  • Display the error code by the result of TQST, then you could soon determine the error in error code table.
  • Monitoring whether the card itself is fault or not permanently. And it will also inform users with the codes when there is something wrong with the cards itself so that avoid misleading users because of the fault of card itself.
  • CPU did not work leading to inability of traditional diagnostic card, the diagnostic card can help you find the reason the traditional diagnostic card doesn't work, you can continue to test the motherboard with traditional diagnostic card after troubleshooting.
  • The diagnostic card do not need new version information of BIOS, meaning of codes is clear, accurate and complete. It can monitor characteristics of post code of BIOS the whole process and reduce the misleading to users caused by traditional diagnostic cards.
  • Completely break the limitations of function of traditional diagnostic cards, not only the standard interface of PCD, but also innovate various auxiliary security parts of improving the accuracy and reliability.
  • Stability test card can tell you whether your computer is stable or not, no matter your computer works stable or unstable. And it also can help find the factors, not matter are invariable factors or variable factor as occasional and invisible potential factors.
  • sort by: active | newest | oldest
    lemonie6 years ago
    OK - what does it describe?
    L
    Vyger (author)  lemonie6 years ago
    Mini 6 Digits Motherboard Analyzer for Laptop with User Guide
    lemonie Vyger6 years ago
    Wonderful!
    L
    I am wondering if it was also the emergency instructions for the Japanese Nuclear reactor.
    "Display the error code by the result of TQST, then you could soon determine the error in error code table. it also can help find the factors, not matter are invariable factors or variable factor as occasional and invisible potential factors."
    Burf6 years ago
    That's what happens when you use a Babelfish translator.
    blkhawk6 years ago
    I had two "cheap" POST diagnostic cards that worked well. They are helpful to a point since it only diagnosed mostly motherboard problems that are easily fixed by replacing the motherboard. I always replaced the motherboard and the Power Supply at the same time.
    caarntedd6 years ago
    Have you ever googled Chinglish?
    aelias366 years ago
    Many Engrish has this description of card of diagnostic.
