I forgot my PDF password, help ,PL
A PDF password remover (also called a PDF password cracker, password reset, or password recovery tool) is a program that can be use to either remove, find or bypass the security on a PDF file.
Content Table:
1. PDF Password Recovery 5.0
2. PDF Crack
3. Freeware PDF Unlocker
1.PDF Password Recovery 5.0 is an easy-to-use tool designed for removing passwords added to Adobe Acrobat PDF documents.
Method: It helps to decrypt protected Adobe Acrobat PDF files which are preventing the file from editing, printing, selecting text and graphics(and copying them into the Clipboard), or adding/changing annotations and form fields. With PDF Password Recovery, PDF decrypt can be done instantly. Decrypted file can be opened in any PDF viewer with edit/copy/print functions.
Limits: This PDF Password Recovery supports all versions of Adobe Acrobat. It also recovers document open passwords.
My Test: All versions through Adobe Acrobat 9.0 are supported.
Decrypt PDF files protected with owner passwords.
Support all Service Packs.
http://www.reset-password.net/three-new-top-pdf-password-recovery-tool.html
Re-design7 years ago
Was it "greenbeans"?
annyyu227 years ago
PDF Password Recovery 5.0 is an easy-to-use tool designed for removing asswords added to Adobe Acrobat PDF documents. It helps to decrypt protected Adobe Acrobat PDF files, which have "owner" password set, preventing the file from editing(changing), printing, selecting text and graphics(and copying them into the Clipboard), or adding/changing annotations and form fields. Pdf decrypt is being done instantly. Decrypted file can be opened in any PDF viewer without any restrictions -- i.e. with edit/copy/print functions enabled. All versions of Adobe Acrobat are supported. It also recovers document open passwords. http://www.recoverlostpassword.com/products/pdfpasswordrecovery.html
