I have a different breadboard and can't figure it out?
I have a different breadboard and can't get my led to work. Can someone please help? r3dc0rn89@gmail.com
Picture of I have a different breadboard and can't figure it out?
bekathwia1 month ago
Yours is just a bit longer than the one pictured, it works the same way!
Wraithbourn1 month ago
It's hard to tell from your picture, but it looks like you haven't actually closed your circuit. Are your power strips on the outsides of the board connected across on both sides, if not, then the Yellow Wire doesn't seem to be in the right place. make sure that you are going from the negative (blue) strip to the led, then the led to the resistor, then the resistor back to the positive (red) strip, and that your black and yellow wires are hooked in on the same side of the board. See if that helps!
