loading
I have a nanny-cam that runs for 2.5 hours on a 9v. How can make it so - with more batteries - it can run all day?
I would like to put a number of 9v's in a series, but fear the aggregated power will burn out the unit. What can I do to supply the camera with consistent power so as to make the camera run for longer?
NachoMahma8 years ago
. Put the batteries in parallel, not series. Plus-to-plus and minus-to-minus.
If your security camera uses 9 volts you can use any 9 volt battery (not just the small rectangluar one we all call a 9-volt).
The time you get from any battery depends on the capacity of the battery and your power draw from your particular camera.
A typical small 9 volt alkaline battery is about 200 mAh so if this type of battery will run the camera for 2.5 hours then you can do the math of what a bigger battery will run it for if you know the mAh.
This rechargeable battery is rated at 1250 mAh would work for about 15 hours with your camera: http://www.bigsecurity.com/OasisCRM/shopping-Directive-ItemList-Parent-30-Category-I133.htm
If you wanted it to be as small as possible to keep it covert you could use a small 9-volt lithium battery that is the same size as a normal 9-volt with a 500 mAh rating.
If you use a battery that isn't designed for your camera you may need to purchase or make a power connector or you could splice your camera power into the battery wires.
WARNING: Make sure you get the positive/negative polarity correct if you mess around with the power wires and connections or you will damage the camera.
kelseymh8 years ago
https://www.instructables.com/id/Add_an_AC_adapter_to_a_battery_powered_device/
(yes, I'm tooting my own horn, but since I have a possible answer I might as well point to it).
Clotario (author)  kelseymh8 years ago
Thanks Kelseymh and Keydogstony - the camera came with an outlet adapter but using it destroys the 'covert' element that I'm looking for. After doing a little research (and actually thinking about it, Duh) I've decided to try out this http://www.reuk.co.uk/High-Capacity-Alternative-to-9-Volt-Battery.htm or just a simple parallel circuit.
Thanks again!
:-) Ah, you make an excellent point about covertness (and I should have thought of that). And that is a very nice link -- it's cool that a commercial shop provides such clear and complete DIY instructions, along with links to buy the components from them.
I love these DIY sites. They offer so much! Just went out and grabbed a 8 AA battery holder (that has a 9v terminal built in) for $2 at radio shack, I'm going to try to see if I can just do a straight plug-in without any moderators tonight and see if the camera doesn't blow up. I liked your efforts toward rigging kids stuff to bypass the batteries (oh, the C batteries we have gone through...) and am going to keep that around if I ever have time to try to replicate it.
keydogstony8 years ago
You could use a 9v battery emiminator. You can get one at Radio Shack.
