loading
I have been asked to investigate how to make "a crystal stone the size of a tennis ball or a bit larger." low budget
As part of a very low budget film I have been asked to research how to make a prop from the following specification
"We need a crystal stone the size of a tennis ball or a bit larger.  It can be any shape but it must have colour (real of illuminated)."
The reference has been given as a Copper Sulphate Crystal we are an a deadline for mid Feb so any help would be fantastic
I have added reference pictures also
All responses gratefully received
Regards Peter?
Picture of I have been asked to investigate how to make  "a crystal stone the size of a tennis ball or a bit larger."  low budget
Burf5 years ago
When I was a kid I used to grow sugar crystals, many of which were baseball size and almost any color I wanted. All it requires is supersaturated sugar water, some cotton string, food coloring and time.
Just google how to make rock candy and get started. Its almost ridiculously easy.
peterwalsh66 (author)  Burf5 years ago
Thanks very much for the message I will look into it how long would it take to grow a sugar crystal that size? we are on a tight timescale
regards Peter
There are a lot of variables but if your solution is completely saturated and you use a very large mouth jar in a low humidity environment, you should have some good results within a couple of weeks, depending on how big you grow the crystal.
Excellent will definatelly give it a go
Cheers Peter
bivens552 years ago
how do you make a big crystal
you could grow a sugar crystal with an led in the center..that would look cool.
peterwalsh66 (author)  skatattookid5 years ago
thanks very much will have a go and see how it comes out
cheers Peter
rickharris5 years ago
OK if you would be happy with something solid rather than clear - Get a lump of polystyrene - the stuff used for packaging or insulation. Available from your local DIY store
You can carve this with a hot knife (do it outside the fumes are unpleasant) or
You can carve it with normal hand tools- saws - files - sand paper - very easily and fast to the shape you want - then paint it with water based paints.
Its cheap as well. If you can find suitable packaging then free
peterwalsh66 (author)  rickharris5 years ago
Thanks again Rick,
we are looking for something that can be illuminated so it looks like it has an inner glow as it it to represent a fuel cell which either can be fully charged (illuminated) or in various stages of charge.
So we might need to create a resin crystal which we can colour with various lighting perhaps
cheers Peter
Believe me you will be FAR FAR better off moulding something in a clear or colored resin. You can get spherical candle moulds that will work for this.
If you can handle a solid color then colored plaster would work and be even cheaper.
thanks very much Rick that is the way that I am thinking also but I do not know how to do this either.
We are looking for something that looks like a crystal shape etc but is not actually a crystal so would welcome an instructable on how to fashion a fake/prop crystal also.
thanks for the response
Cheers Peter
