3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
I need a good way to very closely bind two strips of metal at a point.?
I saw and tested http://www.instructables.com/id/How-to-sharpen-a-knife-with-a-nail-clipper-2/
It works amazingly well, as long as you don't mind a few scratches on the blade.  I like it but a nail clipper is way too small for a couple of my knives,  (chef's knife, buck knife,  etc.)  I'd like to imitate the effect using a piece of steel I have.  What would be the best way to attach the pieces together?  I considered a pop rivet but I don't know it would stand up to much use or be tight enough.
Recommendations?
Jun 11, 2011. 1:49 AM.Unknown. says:
A few ideas;
Can you weld? Go for that.
Solder, which would work alright on steel. It's not exactly the strongest of choices though.
Glues like 2 part epoxy will not last for long, obviously, but you can reapply and it's (reasonably) quick & easy.
A pop rivet would still probably be a better choice, though...
Jun 11, 2011. 2:02 PMalexhalford says:
Spot welding.
There are a few instructables on making a spot welder, but if you only need to weld this one thing, it may be easier to find someone who owns one (a mechanic, maybe...).
Cheers, Alex.
Jun 11, 2011. 6:35 AMQuercus austrina says:
Try: bolt, washers, lock washer and nut. This has worked for a very long time.
Qa
Jun 11, 2011. 2:39 AMrickharris says:
Actually for the price they are it's far better to buy a knife sharpener that works in the same way but has carbide blades. this is the one I have from Amazon and I have never had such sharp cooking knives/ Also works with all other blades as well.
£9.25 in the UK. Worth every penny.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
