I need an easy mod for the BuzzBee Double Shot. Any ideas?
Read the question
Ammoking35 years ago
getv a pair of needle nose pliers and grab the thing the darts slide onto in the shells aand twist off i heard it makes the darts flie farther
kking56 years ago
put some tape around the shells so that they dont fly
out off the gun when re-loading
the_mad_man6 years ago
get a small screwdriver or something, and pick out the air restrictors in the breach of the gun.
origamic126 years ago
I know this is problably a bit too late, but you can reduce the size of the barrels by sawing them off. then, you unscrew everything and take out the pulley system, drill a hole out the back of your gun, and thread the string out of the hole. tie the string to a keyring or somthing. to cock the gun, pull back on the key ring. fireing is the same, but this mod makes reloading faster. also, if you can find springs that fit, replace the stock ones with better ones. it may be hard to find springs though because the DS uses a reverse plunger system (i think)
ikeike407 years ago
you could cut the entire back off the shells and take the spring that makes it pop out off then glue the shell in. then you can load faster
spreek7 years ago
you can saw off the barrel and drill the shells
zack attack8 years ago
on the shells, u can make the little hole bigger allowing more air through the shell and hit the dart.
Re-design8 years ago
An easy mod would be to camo it with paint or camo tape.
AJBrawlLvr (author)  Re-design8 years ago
No, a actual modification to the workings of the gun. I already spray-painted it!
