3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
I need help moving some buttons on a GameBoy Color.
I have been working on a modification to a GameBoy Color.  I am basically putting it into another case that I have custom designed for the project.  I was just wondering, is it possible to break off a part of a circuit board and connect it with wires?
I basically just want to move the "A" and "B" buttons 1/2 inch to the right to make them fit in the case better.  I think that will be easier than designing button extensions or something like that.
I included an image to show the board and how the parts are labeled.  It is pretty easy to figure out what portion is what button (thanks Nintendo).
An example of a similar idea can be seen here:  Ben Heck's Portable PS1 (It is a little past halfway down the page, where he shows how the inside was wired.  From what I can tell, he broke his PS1 controller into sections.)
Mar 14, 2011. 11:55 AMbradsprojects says:
Yep, you sure can.
Even though you can see multiple pads for each button, there are actually only two connections for each (if you have at the start button for instance you can see that they are connected diagonally)
All you need to do is solder two wires for each button, when these wires make contact, it will be just as if you pressed the button.
You can check which pads to solder your wires to by turning the gameboy on, then getting a piece of wire and connect it between any two pads for each button (one button at a time) if it does nothing then it means you have just connected two pads that are already connected together. Once you find the two pads that work then thats where you solder your wires to.
Mar 14, 2011. 10:07 PMdaltonjcw says:
DO NOT BREAK THE PCB BOARD! That will most probably kill you gameboy. The gold color leads on the pad are connected when the button goes down. If you connect a wire (solder carefully) to each of the leads, when the wires touch, it sends the signal for A or B. Worth checking to make sure you did it right. cool project, Cheers!
Mar 15, 2011. 9:07 AMgeoslim13 says:
those gold color leads are real gold!
Mar 14, 2011. 9:29 PM7654321 says:
Just make sure you connect any/all broken traces
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
