loading
I need help with arduino code. Can someone help me remove the ping sensor from the code below?
I need to take the ping sensor out of this code. I want the robot to drive around like crazy until it bumps into something with the bump switch.
/* Rumblebot Driving with object avoidance utiliszing PING Ultrasound Sensor
* and a bump switch.
* Reads values (00014-01199) from an ultrasound sensor (Parallax PING)
* Version 1.1.2 Motor runs and drives full time unless object detected.
int switchPin= 2; // Right bump switch on pin 2
int swval; // Variable for reading switch status
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;
int ultrasoundValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
int motorpinright = 10; // pin for left motor reverse
int motorpinleft = 11; // pin for left motor forward
int motorpinrevright = 5; // pin for right motor reverse
int motorpinrevleft = 6; // pin for right motor forward
void setup() {
pinMode(switchPin, INPUT); // Sets the digital pin as input
pinMode(ledPin, OUTPUT); // Sets the digital pin as output
pinMode(motorpinright, OUTPUT); // Motor drives-----------
pinMode(motorpinleft, OUTPUT); //------------------------
pinMode(motorpinrevright, OUTPUT); //------------------------
pinMode(motorpinrevleft, OUTPUT); //------------------------
void loop() {
/* Start Scan
timecount = 0;
val = 0;
pinMode(ultraSoundSignal, OUTPUT); // Switch signalpin to output
/* Send low-high-low pulse to activate the trigger pulse of the sensor
digitalWrite(ultraSoundSignal, LOW); // Send low pulse
delayMicroseconds(2); // Wait for 2 microseconds
digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
delayMicroseconds(5); // Wait for 5 microseconds
digitalWrite(ultraSoundSignal, LOW); // Holdoff
/* Listening for echo pulse
pinMode(ultraSoundSignal, INPUT); // Switch signalpin to input
val = digitalRead(ultraSoundSignal); // Append signal value to val
while(val == LOW) { // Loop until pin reads a high value
while(val == HIGH) { // Loop until pin reads a high value
timecount = timecount +1; // Count echo pulse time
/* Lite up LED if any value is passed by the echo pulse
if(timecount > 0){
digitalWrite(ledPin, HIGH);
delay(50); //LED on for 50 microseconds
digitalWrite(ledPin, LOW);
/* Delay of program
delay(100);
/* Action based on data
ultrasoundValue = timecount; // Append echo pulse time to ultrasoundValue
if (ultrasoundValue > 800)
/* Drive straight forward
analogWrite(motorpinleft, 255); //100% speed
analogWrite(motorpinright, 255); //100% speed0
else
/* Turn hard right
analogWrite(motorpinleft, 0); //stop left motor
analogWrite(motorpinright, 0); //stop right motor
analogWrite(motorpinrevright, 0); // stop right rev motor
analogWrite(motorpinrevleft, 0); // stop left rev motor
analogWrite(motorpinrevright, 255); //100% speed
delay(380); //380 milliseconds
analogWrite(motorpinrevright, 0); // off
analogWrite(motorpinleft, 0); // off
/* Backup and turn right when switch gets bumped and closes circuit to ground
digitalWrite(switchPin, HIGH); // Sets the pin to high
swval = digitalRead(switchPin); // Read input value and store it
if (swval == LOW) {
analogWrite(motorpinrevleft, 255); //100% speed
delay(800); //800 milliseconds
analogWrite(motorpinrevleft, 0); // off
analogWrite(motorpinrevright, 255); //100% reverse speed
analogWrite(motorpinleft, 255); //100% forward speed
delay(700); //700 milliseconds
delay(50); //50 milliseconds
UPDATE
I tried deleting some stuff and changing some stuff. When I turn on the robot noting happens. Here is the code after the changes.
int val = 0;
void setup() {
void loop() {
/* Start Scan
timecount = 0;
val = 0;
/* Delay of program
delay(100);
if (true)
else
/* Turn hard right
if (swval == LOW) {
orksecurity6 years ago
If you don't want to issue the ping or respond to it , and you don't understand the code, the simplest instructions I can give you are:
(1) Remove or comment out everything between
and
/* Delay of program
(2) Then, change
to
if(true)
That will do the job. The else clause under that if(true) is wasted code but won't do any harm; you can clean it up later.
I strongly recommend you study this until you understand why my changes do what you want, so you're in a better position to make the next change yourself.
TOCO (author)  orksecurity6 years ago
Thank you! It works. At least it didnt find any errors. I will wire in the bump switch and upload the code.
TOCO (author) 6 years ago
Here is the wiring schematic http://www.dinofab.com/Images%202.0/rumblebot%20schematic.jpg
