I need to melt and cast brass - will this work? I haven't seen the melting temperature between brass and aluminum.?
Edgar8 years ago
Use a gas fired foundry, Google those words, you'll get a lot of anwers.
Gorfram8 years ago
Zinc oxidizes very easily and quickly, which may be a severe problem at high temperatures. Adding charcoal to the crucible to scavenge the oxygen may help some. And the fumes are indeed very, very nasty. Would bronze (copper alloyed with tin instead of zinc) work for your project?
jtobako8 years ago
Brass melts higher, close to 2000 F. You need slightly different material for brass cast due to the higher temp. There is minimal risk of zinc fumes as long a you have good ventilation, and the higher temps have there own risks. How much are you trying to melt?
lemonie8 years ago
Casting brass is a job for professionals, it's not easy and it is dangerous (fumes). It is harder to do than with aluminium. L
kelseymh8 years ago
Use Wikipedia to find the melting points. Then judge for yourself.
