I need to push a button across a room and I need it wireless....I have a 12v wireless remote already.
http://www.amazon.com/RM01-Channel-Wireless-Control-Off/dp/B000ZRXJY2/ref=sr_1_19?s=electronics&ie=UTF8&qid=1334442767&sr=1-19
...Here the story..
I have to weigh and fill 55 gl drums at work.
My employer placed the scale control across the room. ( I filling 190 proof ethyl Alc.)
I need to clear the scale after each drum(which is a push button).-With 4 on a pallet..its not the most efficient system.
My wireless remote seem to react quickly with the on button, not so much with the off.
--I tried an old lock actuator I had and this would push the button with enough force,
but naturally would not return.
Any ideas from the pros?
Thanks- Josh
It is very easy ! What is the output of your wireless remote ? If it is relay then you can make that output a momentary one. That is once you press remote button, the output will be on for a second or so and it will be off after that time. Use this output parallel to your button on the scale.
Wheredagoldat (author) 5 years ago
Thanks Frollard and Iceng for your responses.
You are correct. I am zeroing or "tare" the scale between loads...
Stapler-sounds like an easier solution for me the amateur..
-iceing- With the last setup-the lock actuator. When I pressed on.
It was opening the switch-allowing current to move the actuator and off ideally to stop the current..or close the switch.
-I assume my terms arent correct here...being a tinkerer..i don't read alot of "instruction manuals" lol- I just guess
Thanks so much for your help. this will save me some time for sure.
frollard5 years ago
If I understand correctly you have to zero 'tare' the scale between loads?
If so you have a few options, like you tried already with something that physically pushes the button -- or if you are able, open the control panel up and wire a relay in to short the switch out momentarily to do the zeroing.
A wireless doorbell circuit could be used to make the actuator - some even have relay outputs on the circuit board; others you would have to detect the door sound and use that to actuate the switch.
Otherwise, you need a solenoid or gearmotor to push the button - I have an electric stapler that uses a cam to push the staples through - it uses another cam to disable the motor after a complete revolution, and the external switch causes the motor to start.
iceng5 years ago
What does the off button need to do if the on button clears the scale ?
A
