Here's a link to an online conversion tool (from mm's to inches). Once you have the diameter of your nichrome (in mm's), use the conversion tool to figure out which gauge you have. (I had to type out the chart from info I have here at home, and its only in inches).
For sort of a sanity check, you can examine your unknown wire, side by side, with some other pieces of wire you know the gauge of. Frequently this number printed on the insulation of the wire, or well known for certain kinds of well known wire. E.g. CAT5 network cable has size 24 AWG solid copper conductors, and you might have some of that lying around.
The other way to measure gauge, is to realize that nichrome wire has certain resistance per unit length, that depends on the gauge (i.e. how thick the cross section is). So you can take a length of this wire. Then measure the electrical resistance with an ohmmeter. Then divide that number of ohms by the length of the wire.
For example, if you have 2.0 meters of wire, and the electrical resistance of this measures 6.6 ohms, then the resistance per unit length is 3.3 ohms/m, or 3300 mΩ/m. The resistivity of nichrome is about 64 times that of copper. So divide 3300 by 64, to get 51.6 mΩ/m, for the same piece of wire made out of copper. Then you can look that number up in the AWG table I linked to above, and again here: http://en.wikipedia.org/wiki/American_wire_gauge#Table_of_AWG_wire_sizes and find that 22AWG copper has a resistance per unit length of 52.96 mΩ/m. Then you sort of guess that your wire is also 22 AWG, or something close to that, since 52.96 is the closest number you can find to your measurement of 51.6.
You can read more about the resistivity of nichrome wire here http://en.wikipedia.org/wiki/Nichrome and that article is where I am getting my numbers from.
This second method, based on measuring electrical resistance, might sound like more trouble than its worth, but if you are building a heating element, then the actual electrical resistance of the heating element is the number you are interested in anyway. I mean that's assuming you're driving it with a voltage source, and the power it dissipates is just P=V2/R (from Ohm's law), and that's the number that determines in part whether you are making the wire warm, hot, or melting it.
The wire will get hottest in those places where it is best thermally insulated, e.g. the middle of the wire, surrounded by still air. If you stick the hot wire into a block of foam, naturally it will cool down somewhat , as heat is transferred to the melting foam. I mean that's sort of the game that's being played here. P=V2/R puts heat into the wire, and then heat transfer through materials surrounding the wire take the heat out of it.
I guess what I am saying is that number P=V2/R, the total power dissipated by your hot wire, is an important number, and to measure R you don't actually need to know the AWG gauge number of the wire, you just need to know its resistance per unit length, and you can measure that with an ohmmeter and a tape measure.
I forgot to mention, for using an ohmmeter to measure resistances this small, i.e just a few ohms, you should take into account the resistance in the probe wires plus contact points.
First you take a measurement with both probes touching the nichrome wire, and with the probes touching each other. That is to say a zero length piece of nichrome wire is contributing to the resistance measurement. Suppose the meter says 1.2 Ω.
Then do another measurement through 1 meter of nichrome wire, and the meter says 4.5 Ω. Then do a measurement through a 2 meter piece of nichrome wire, and the meter says 7.8 Ω.
That is to say, with each additional meter of wire, the resistance increases by 3.3 Ω , and that's the number you're interested in. I.e you are expecting proportional increases in the length of the wire, to result in proportional increases in the resistance of the wire.
i dont know about nichrome wire but with fencing wire, the higher the number, the smaller the wire. i'd just compare it to some normal tie/fencing wire and the gauge should be the same.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
The numbers in this table were were copied from the Wikipedia article on American Wire Gauge, I linked to previously, here:
AWG
Diameter
(inch)
(mm)
0000 (4/0)
0.46
11.68
000 (3/0)
0.41
10.4
00 (2/0)
0.36
9.27
0 (1/0)
0.32
8.25
7.35
6.54
5.83
4
0.2
5.19
5
0.18
4.62
6
0.16
4.12
7
0.14
3.67
8
0.13
3.26
9
0.11
2.91
10
0.1
2.59
11
0.09
2.31
12
0.08
2.05
13
0.07
1.83
14
0.06
1.63
15
0.06
1.45
16
0.05
1.29
17
0.05
1.15
18
0.04
1.02
19
0.04
0.91
20
0.03
0.81
21
0.03
0.72
22
0.03
0.64
23
0.02
0.57
24
0.02
0.51
25
0.02
0.46
26
0.02
0.41
27
0.01
0.36
28
0.01
0.32
29
0.01
0.29
30
0.01
0.26
31
0.01
0.23
32
0.01
0.2
33
0.01
0.18
34
0.01
0.16
35
0.01
0.14
36
0.01
0.13
37
0.11
38
0.1
39
0.09
40
0.08
38 = .0040
36 = .0050
34 = .0063
32 = .0080
31 = .0089
30 = .0100
29 = .0113
28 = .0126
26 = .0159
25 = .0179
22 = .0253
21 = .0285
20 = .0320
19 = .0359
18 = .0403
17 = .0453
16 = .0508
15 = .0571
14 = .0641
11 = .091
The so called "gauge" of wire is a specification related to its thickness. So one way to measure this, is to measure the diameter of the wire using a ruler, or a micrometer,
http://en.wikipedia.org/wiki/Micrometer
if you've got one of those.
Then look up that diameter in in a table, like this one:
A
