I want to build a power supply input 12 or 24 VAC output12VDC?
iceng5 years ago
Here you go INPUT 24VAC and OUTPUT 12 VDC..
Just ignore the 5 VDC section.  .  .  . A
Basem Salep (author)  iceng5 years ago
thanx for this but i see it's very complex
if i make 12 VAC input and 12VDC output will be the same desing?
You Scare easy :-)
12VAC makes the reg ripple much worse .
I cut the parts that made a Cadillac, now you have a Ford.
A
iceng5 years ago
Reg = Regulator
Accepts up to 35 volts on the input pin with respect to ground.
and regulates 12 volts on the output pin with respect to ground.
ok many thanks Mr.Iceng i'm already working to do it
lemonie5 years ago
From what?
L
Basem Salep (author)  lemonie5 years ago
from a trasfomers and four diods ...i don't if i have to use anther components?
Just use the four diodes like iceng has in that diagram.
L
Re-design5 years ago
Google "12 v power supply" and take your pick.
