I want to buy a new laser cutting machine. I need a suggestion.
The machine i am looking for should be approximate working aria of 45cms/100cms .  For SS, brass and aluminum cutting and engraving. Please anyone suggest me witch brand is best ?
Check this out if your looking for a new desktop laser cutter / engraver.
desktop tool that uses laser cutter/engraver technology to shape wood, leather, fabric & more at an amazing price. copy desktop tool that uses laser cutter/engraver technology to shape wood, leather, fabric & more at an amazing price.
there a crowdfunding campaign going on right now http://glowforge.com/referred/?kid=0J8Izb
Working bed: 12″x20″ (300mm x 500mm)
Maximum thickness of material with tray installed: 0.5″ (13mm)
Maximum thickness of material with tray removed: 1.5″ (38mm)
Focus range: 0.5″ (13mm)
rickharris4 years ago
1, Where are you in this wide world we live in.
2. If you can take the risk Ebay is most likely the cheapest - but laser tubes are delicate.
3. Metal cutting machines are industrial and therefore costly - CNC Plasma cutting may be an option
Some examples of what is available in the UK.
http://hpclaser.co.uk/index.php?main_page=product_info&cPath=1&products_id=11
usersri (author)  rickharris4 years ago
I am in Bangalore, INDIA.
Then the advice given here is still valid.
frollard4 years ago
You can get a desktop sized lower power model that can etch/cut anything less dense than metal for less than a thousand dollars ranging up to about ten thousand dollars...they are in the 'less than 120 watt range'.
Problem is, cheaper infrared lasers simply don't even touch metal. Without an oxygen stream, it doesn't happen. To cut metals you need a higher power (often YAG) laser. Those can range in the tens to hundreds of thousands of dollars.
