3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
I want to experiment with wind power on a small scale. What type of salvaged permanent magnet motors work best? Thanks!
May 24, 2011. 7:37 PMdukexyz says:
I have a 155V DC generator @15 amps. I could not get the speed to get more than 50 volts. I build a pulley system with a ration of 4 to 1. Works beautifully how ever I cannot make the pulley shaft and bearings maintain concentricity for very long. There must be a system out there already in use so that I don't have to re invent the wheel. Do you or does anyone out there know of someting that is already in use? A gear drive would work even better!!
Dukexyz
Sep 25, 2010. 2:07 AMrickharris says:
A stepper motor salvaged from a printer or scanner will be a reasonable starting point for small scale experimentation - BUT don't expect to be producing commercial amounts of electricity from it.
Sep 24, 2010. 3:12 PMsteveastrouk says:
Avoid ones that work at ridiculous speeds on lowvoltages. The toy motors can be 8000 RPM on 3V !
You want ideally a nice big 1500 RPM, 120V DC motor, so that you can get reasonable speeds on the blades, into the motor - in the example 1500 RPM @120 V would be, roughly 150 RPM= 12V. Such beasts DO exist.
You MUST have the speed at the motor, so you'll need (lossy) belts or gear drives otherwise.
Sep 24, 2010. 3:08 PMfrollard says:
'small scale' -- depends how small. Most any PM motor will work, just add diode bridge!.
The size/cost tradeoff will show its ugly head quickly as the size increases, the cost can get pretty ugly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
