I would like to make a miniature ferris wheel. I need the wheel to spin smoothly and I don't know how to start. help?
I want to make a miniature ferris wheel for a little project, and I want the wheel to spin smoothly. I know absolutely nothing about bearings and axles and such, though I do have some experience in basic DIY and construction projects. What would be the best way to go about this? (and not terribly expensive either, Thanks!)
Toga_Dan23 days ago
low rpm is very forgiving. Sloppy fit is OK.
fella37532324 days ago
or like on a bike, you know the part that connects
how abot a needle? search up ferris wheel and look at ones with a needle like thing sticking out on each slide and something going down to support it. Look!
seandogue25 days ago
How miniature? For anything smaller than about a foot in diameter, a sleeve bearing should be fine.
https://www.bing.com/shop?q=sleeve+bearing&FORM=SHOPPA&originIGUID=55E3C422F67F442DB94B7C6B0EB78AA7
rickharris26 days ago
Bearings have 3 main dimensions.
The outside width
The inside diameter
The depth (front to back)
so typically the specification may look like:
  • Product Name : Deep Groove Ball Bearing;Type : 6205RS
  • Material : Carbon Steel, Rubber;Outer Diameter : 52mm / 2"
  • Inner Diameter : 25mm / 1";Thickness : 15mm / 0.6"
  • Color : Silver Tone, Black;Weight : 126g
  • Package Content : 1 x Deep Groove Ball Bearing
(from amazon)
All you need to match is the inside diameter to your shaft and the outside to the object turning.
However this may be hard if you don't have access to a lathe.
You could make these by buying a shaft of a suitable diameter and wrapping plastic or paper round the outside of the bearing.
Or as Iceeng says you could use ta geared motor as one bearing and just grease the other end where it passes through the support leg.
Click on images for full size.
iceng26 days ago
Use a gear motor... It runs off of AC Mains or 12 VDC or 24 VDC and would rotate very smoothly...
Are you familiar with Lego as an Engineer's construction design tool...
How big is this miniature Ferris wheel ? How many spokes ? How heavy ?
