3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
I would like to power a 12v dc 10amp water pump with a 120v power source...Ideas???
What could I use to do this without actually buying a $100 converter...I have read some instructables on using a pc power supply to make a bench power supply...but that seems like more than I need...any ideas???
Feb 11, 2011. 11:00 AMSharpyWarpy says:
First let me say I know this thread is old.
A microwave oven transformer will give you all the current you want and more. Cut off the secondary winding (small wire with 2000 turns) and wind 12 turns of 16 gauge wire. Connect this to a rectifier bridge and to your motor. Check the voltage at the motor while running. You might need to remove one or 1/2 winding on the transformer. It's a good idea at that amount of current to heat sink the rectifier -- you'll want a 30 amp one, about $4 -- and put a fan on the transformer. Those are the basics. More if needed, I'm here a lot.
Oct 23, 2009. 2:35 AMkramerr says:
10 amps is more than a typical PC power supply can put out. PC power supply will shut off automatically if you try to draw too much current.
What you can always do is use more than one power supply and connect the 12v output in parallel. Current adds up that way.
Is there a reason why you want to use a PC power supply? A regular transformer (wall wart) will work fine. When I visit my local second hand store there's a rack of old transformers meant for battery chargers, telephones, modems and so on. Just find one that says 12V and at least 10 amps, it won't hurt if its greater, and you can put these in parallel too if you like.
Oct 22, 2009. 4:34 PMalex-sharetskiy says:
A lead acid battery
Oct 22, 2009. 6:44 AMMahavishnuMan says:
Run the mains into a transformer with 10:1 reduction, then through a rectifier bridge.  Finally, a voltage regulator (preferably switching for efficiency) as the rectified DC output will be above 12 V.
Keep in mind that most outlets are only capable of 15 A total, so you don't want to run anything else on the same outlet as this device for safety reasons.
Oct 22, 2009. 12:14 PMsteveastrouk says:
That last bits wrong, you can pull 15A at 120 V from the supply, or 1800 Watts. Here, he only wants 120W, so there is no problem at all.
Oct 22, 2009. 12:47 PMMahavishnuMan says:
Oops, that's what I get for being a smarty-pants before my first cup of joe.
Oct 22, 2009. 10:46 AMseandogue says:
One way or another you'll need a DC supply. I suggest that you look up some surplus electronics suppliers. They often have "pulls" that are sufficient for high current drive at much lower than retail cost.
Oct 22, 2009. 8:53 AMjeff-o says:
Hmmm, that's outside the range of a typical computer power supply, too.  Hvae you looked on eBay for a suitable power supply?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
