Where can I get full UV LEDs?
I need some full ultraviolet LEDs for a project. I've found some, but they don't output light completely in th UV range. These lights also put out visible violet light; I need them to give me invisible UV light. The wavelength that they put out needs to be around 300nm-350nm. Thanks.
So add a violet filter.....
DIY Emilio (author)  steveastrouk6 years ago
I figured that I would just have to do that if I wanted to get a nice UV-only output. I've only found LEDs in the 390-405nm range. These probably put out enough mixed in UV light to be filtered.
nicelly5 years ago
If you don't want to destruction up your eyes and are keen to purchase the best type of rayban sunglasses, then you should obtain them from your expert vendor. You will have a lot of different developer cups support frames to select from and they can include the best type of protecting lens. Whether
ray ban occhiali's rayban sunglasses you need or another type of developer makes for instance, buy from an expert so you won't regret it.
dog digger6 years ago
You can get them but they are a very specialized LED. Try online electronics stores and I know that dealextreme have relatively good ones
frollard6 years ago
Never heard of em. Simply put, they haven't found
a) a phosphor that emits just that wavelength
b) efficiently enough for it to be profitable enough to manufacture.
Both conditions must be met. That said - the near visible ones often put out a range, and some of it is in the invisible range -- enough so that they can be used to expose UV sensitive films/resists/etc. You won't be making an LED tanning bed any time soon.
DIY Emilio (author)  frollard6 years ago
I actually want to use a modified camera CCD to make a USB UV microscope that can get a little more powerful than normal microscopes. Tubes take too much power for this. I might do better to use a more focussed laser in the shallow or near UV range (I haven't found a full UV diode yet, and doubt there will be an affordable one).
