I'd like ideas for a domestic ejection-seat, any about?
For artistic purposes, "we" are interested in making an ejection mechanism to remove a person from a household arm chair.
I've thought of>
Springs
Gas-rams
Sealed gas-struts (car tailgate)
My main sticking points are: pushing the thing down if not using active gas-power, and the hassle of gas valves etc.
All suggestions welcome
33
answers
Answer it!
Do you have something you could put in a diagram/picture?
L
-Noahh
someone will have to help you compress them
A
Lemonie is very proper centric.
But to be realistic in the sense of a MythBuster
You got to get Dangerous :-)
A
I'm judging this to be the best answer given. The problem I have with this type of mechanism is the force needed to compress the springs, still I suppose two people could set the thing.
Thanks
L
Work for you ? A
You realize... aww Steve already said it.
Do you watch the Myth Busters ?
They did a rocket chair, four rockets, one per chair leg.
The chair dummy got flipped and killed.
There was no balancing four chemical rates of burn !
A
The motivation is to make it, rather than use it.
L
That'd be a rocking-chair type tip, and that had been thought of - how might the tip be driven without tipping the whole chair?
L
I had thought of that (more like seatbelt pre-tensioners) but these things are hazardous and I don't know whether they are left in at car salvage yards.
Also, they only work once.
Thanks for the suggestion though.
L
For practical purposes, I suspect there is no good answer.
For artistic purposes, I'd uses compressed air to move the chair at a 45 degree angle to the base with a force of around 40-50 lbs more than the chair. Use slides/rails to provide positive stops and to keep the chair and base connected. Even if it doesn't "eject" a person, the sound will make them move.
Qa
http://www.usmedicalsupplies.com/Lift-Chairs.htm?utm_source=business&utm_medium=cpc&utm_content=default&utm_campaign=liftchairs
For artistic purposes, there's an idea behind it (a joke if you prefer).
L
But...
My mum uses a riser(?) chair that simply has a lever - in the locked position, it's a normal chair, but dis-engage it, and the springs inside will push you and the seat up.
The lever is then used to assist in sitting back down - which also helps compress the springs before latching the lever back in place.
I don't know about the internal construction, but there may be a possibility of swapping the springs for stronger ones, though that would make the lever harder to operate (even if you lengthened it, probably).
But for artistic purposes the riser(?) chair may be too much of an obvious cliche.
Non forceful or non powered things that would work could be really bad smells and sounds that would cause a person to quickly move.
There are a lot of assist chairs on the market, they all use motors. Motors are slow enough so any kind of injury is often avoided. A chair that simply "stands up" leaving no place to sit on it would be pretty interesting. A slow motion eviction. Also a slow motion set of spikes coming up through the cushion would get attention, eventually. That would be fun to do with a dog.
If you are talking about ejection as in thrown out, its a bad idea inside a house. With low ceilings any kind of abrupt powered device is likely to throw someone into the ceiling and could cause pretty serious injury including broken necks and even death. Hmmmm a new and interesting form of execution? "Have seat, the executioner will be with you shortly"
Mythbusters did a segment on car ejection seats. They used compresed air and it worked better than they thought it would. It launched Buster quite a distance. (Buster is a test dummy)
For artistic purposes, a proper throw-out/off is what's required. Perhaps only for demonstration purposes without the full lifting force.
L
