loading
Ideas on how to make a flimsy plastic sword stiffer?
I'm going to be a in a production in a few weeks and the swords for our guards just arrived yesterday. They are great, and we got them for a great price. Only problem, they are about 36 inches long and kind of flimsy. They flop a bit when swung. The plastic is solid and looks really good. Any ideas on how to stiffen them up a bit?
kelseymh7 years ago
Way down in the discussion thread below, the author said,
Yes, well the swords are unfortunately not hollow, and incredibly thin. Hence the flimsiness.
This puts the kibosh on any kind of internal reinforcement.  So either you wrap them in something very stiff (sharpened steel keeps coming to mind....) or you bail on them and get something properly sword-like to use instead, like SCA weaponry.
You might be able to do something with fiberglass or carbon fiber, but no matter what, you'll be spending more than what you paid in the first place.
"sharpened steel"...lol. got it out for the actors, aye?
"ooh, so very sorry Nigel, I do believe they may be able to sew that back on...Don't forget to wrap that in a cool, wetted towel before you dash off to the hospital"
I agree though, that there's really not much  that can be done if they're not hollow, at least at can't think of anything off hand.
Maybe make wood swords and spray them with metallic paint.
Only thing I could think of that wouldn't totally change the look or require building from scratch is getting two identical blades and laminating them together with plastic cement.
Of course, then the swords wind up costing twice as much and you have all these extra hilts and pommels lying around....
Now that's a good idea. One could even theoretically place some sort of strengthener inbetween the layers...but yes it would require two and the skill to do the lamination
Theatre tech people tend to be very resourceful (if I do say so myself), so skill shouldn't be a problem. Money, on the other hand...
Down to the model store and buy some of their polystyrene model beams: like the stuff these guys sell www.plastruct.com
seandogue7 years ago
If they're hollow you could fill them with something like plaster of paris, although they'd become a bit heavier and more dangerous
Or resin, which would be a touch less brittle. They'd become bludgeons at that point, though.
or an expanded foam core...
True. Something like a rigid polyurethane would be close to ideal, maybe with a supporting rod embedded, just for good measure. Decent A/B urethane is tough to come by, though.
Yeah. I figure that stuff they sell at home improvement stores might do the trick, though I'd watch out if too much is used ;-)
Yeah, it's great stuff (see what I did there?), but I've had really bad luck with getting it to cure in enclosed spaces. I once used it to fill a severed head prop - latex skin filled with expanding foam from a can. The prop looked great when it came out of the mold, and for a week or so afterward. Then it started to get smaller and more wrinkly by the day. Last time I saw it, it was the size of a grapefruit, and looked like a giant flesh-colored raisin wearing a wig. I've used A/B ever since.
Make sure everything is nice and damp when you spray the one pack stuff. The stuff needs moisture to foam and set properly.
oh...reeeely?  nice tip. ty Steve!
Cabanaman (author)  seandogue7 years ago
Thanks, I'll give that a try next time.
Ah...yeah...I hadn't thought of that. I found out the same with silicon and caulk...it just doesn't want to cure in a closed space.
kelseymh7 years ago
Steel.  Preferably pointy and sharpened along the sides.  Oh, wait, that would be a real sword, wouldn't it?
But seriously, if these are hollow, you should be able to put something like a furring strip inside to stiffen them somewhat.  In fact, if they are hollow, then they will have a lenticular (football shaped) cross section.  You can take advantage of that.
Carefully cut strips of wood (say 1/4" masonite or 3/8" plywood) slightly (1/16" or less) larger than the short cross-dimension.  Now force-fit those strips down the center of each sword-blade.  That should turn it into something more like an H-beam than a tube, and it should become much stiffer in flexion.
+1
I'd go with a fiberglass or graphite rod, just to reduce the possibility of breakage, but the H-beam thing is primo.
