If I hook the 12 v motor from a car air compressor to a crank and the wires to a battery, will I have a hand generator?
I know you'd need diodes, but would I be able to charge a 12 volt battery with something like this (kinda like in that videogame Metro 2033 where you have a hand powered generator- coolest thing ever)?
Jul 22, 2010. 2:24 PMlemonie says:
Yes it should work, but use the gears from the compressor if you can - faster is better (on the motor)
L
Jul 22, 2010. 10:25 PMlemonie says:
Be sure to publish the results, we'd like to see.<
L
Jul 22, 2010. 5:09 AMfrollard says:
Should work -- dc permenant magnet motors do function as generators (with diode bridges to rectify the output)...With just a hand crank it won't turn fast enough to generate 12-14 volts to charge a car battery -- You will need to add a gearbox to up the hand crank turns to 'motorish' rpm.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
