If I want to collect rain water inside a light funnel (glass), how would the drainage system work?
The existing flooring consists of concrete slabs 230mm thick sitting on top of concrete beams 450mm thick, and the diameter on the bottom of the funnel is about 4 meters. Thank you for your help :)
It would be collected for use in the building but that's exactly my question, how would the draining system work? Here is a picture of what the thing would look like.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Where does the water go now ??
A picture would be worth a thousand words here.
Steve
Consider how heavy that funnel will be when filled with H2O
A
