If u cut into a snowboard, does it all peel apart? Or does it keep together?
I'm trying to make a longboard because I don't want to buy a really expensive one. I am going to make it out of a snowboard but I was wondering if I cut into the board itself does it peel apart in layers? Or does it keep and edge?
frollard6 years ago
In theory, the edge should only provide protection from the weather getting in between layers -- they were all saturated with resin and cured in a tight press to ensure the layers bonded...
If you cut it, it will lose some strength, and you'll want to re-seal any raw edge left cut, but it should work -- that said, it'll be WAY too flexible for a longboard unless you had a SUPER stiff snowboard to begin with.
trker (author)  frollard6 years ago
Also how best do you recommend sealing the edge?
frollard trker6 years ago
You want to use something flexible and waterproof -- epoxy is good, but isn't flexible generally, you'll have to do some reasearch in that department.
Roughing up the edge and 'painting' it with some silicone caulking should do the trick.
Ok thanks for that, it was pretty stiff to start out and it's not that long anyway, but we will see how things turn out.
aeray6 years ago
Check out this link. These guys commonly saw snowboards down the middle to use for backcountry access. It'd be a good place to browse about, because they do have to seal the cut edge. I agree with frollard, though, It'll have too much flex.
trker (author)  aeray6 years ago
Thanks for this link, but I can't find anywhere that tells me how to seal the edge
aeray trker6 years ago
The Voile website, which sells DIY splitboard kits says to use "...varnish, varathane, or enamel paint."
