loading
If you place a 1 ohm resistor across a 12 volt car battery, how much power will it dissipate?
This is one of the exercise from the book, "The Art of Electronics." They do not give answers and i wanted to know if i did it right. I got the answer of 1.44 watts, but i am not sure if this is correct.
rickharris2 years ago
Using ohms law:
I=V/R
then 12/1=12 amps.
Watts =V * A
so 12 * 12 = 144 watts.
We would expect a 1 ohm resistor to draw a LOT of amps and so dissipate a lot of power.
Your answer works for a 100 ohm resistor though
12/100 = 0.12 amps
0.12 X 12 = 1.44 watts.
That's only partially correct because most resisitors would catch fire after less than 5 seconds...
Unless you have a 150 Watt resistor, Which I don't know, but I'm guessing they aren't sold as 1ohm
cooldude01 (author)  rickharris2 years ago
Thanks. I had got both answers but i didn't think it was 144 watts because it was so high. Alright thanks lets me know i am on the right track.
Nooo! A 1 ohm resistor is practically a short circuit! It will only drop a volt for every amp of current flowing through it! You can check out my videos about ohms law and watts law and series/parallel circuits on youtube, under the channel Power Max if you're intrested.
It's often useful to take circuits to mental extremes. for example we all know that a total short circuit would draw as much current as the power source can supply. 1 Ohm is not far from that short circuit so the answer is going to be high.
