I'm designing a development board using NRF51822 and I need help to select the appropriate chip antenna.?
Hi Guys,
I'm RF beginner and I'm designing a development board using NRF51822 and I need my board to be small as possible so I decided to use chip antenna but I don't know how to select the appropriate antenna for my case.
So I need help to select the appropriate chip antenna.
rickharris4 months ago
http://www.pulseelectronics.com/wp-content/uploads...
For maximum range you really need a length of wire. This should be normally 1/4 wavelength for the frequency your using.
iceng rickharris4 months ago
+1
Unless you want to go into slivered wave guides and slotted directional antennas ... but then you would have to learn how to calculate the curl of a 2D vector field.
https://en.wikipedia.org/wiki/Vector_calculus_iden...
rickharris iceng4 months ago
You see my head is hurting again! In the 70's I assembled a "special" waveguide system to suit a complex custom installation. All done using hand tools/ i was told it was impossible without special jigs, tools etc. However when tested to wave guide system have one of the lowest SWR they had even seen - Just luck I guess.
