Instructables changed there automatic log out time. Even tho i have checked "keep me logged in" it constantly logs out after a few minutes or so. The problem, when i am putting together an ibble and it has logged out. I can still continue to wright text, but then if i go to save manually all the info i put in after the auto log out is lost at that time of manually saving. If there is an option for the log out time i can not find it. Anybody having this problem?
Now with two firefox updates later I get kicked off due to inactivity so often that I have to capture the text every paragraph just in case it locks or hangs when I post :(
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
http://www.instructables.com/community/Login-Problems/
http://www.instructables.com/community/Problem-with-Logging-Out-Too-Quickly/
http://www.instructables.com/community/Trouble-logging-in-and-appearing-to-be-logged-out/
Delete cookies, clear your cache.
Thank You very much!
post :(
