Inverter question?
I have recently made a pond in my garden and to avoid spending lots of money in electricity, I decided that I would power it with a solar panel. My pump is 220v 34w, so I thought that a 40 or 50w solar panel should work. However, i can't find any 40-50w inverter, only about 150w. So, my question is, will a 150w inverter draw 150w from the solar panel if powering only the 34w pump? In other words, will a 40-50w solar panel be able to power a 34w pump via a 150w inverter or would I need a 150W solar panel for that?
petercd3 years ago
Tthe inverter does have a small idle current even when its doing nothing, but the pump connected to the inverter will determine max current draw, in a nutshell... you will be safe.
tgferreira184 (author)  petercd3 years ago
Thanks.
Check this instructable out. It gives you a detailed guide to setting up a solar system. https://www.instructables.com/id/Apartment-Solar-System/
you need to forget the inverter, they are energy hungry and will require a battery, and solar regulator and some way of turning the pump off and on so the battery is not fully discharged and damaged.
for less than the price of a battery you can solve all of those issues with a dc solar pump, just wire it direct to the panel and your done for $15
also have a look at
https://www.instructables.com/id/Vermiponic-Garden/...
http://www.ebay.com.au/itm/12V-DC-Submersible-Wate...
tgferreira184 (author)  liquidhandwash3 years ago
I can't buy a new pump, I have just bought and installed mine.
+1
