3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Is a laser operated button pusher possible?
We have a business convention coming up soon. Inside of our display case we have this grid of LED panels. The goal of the display is you try and hit a button outside of the case when a certain LED panel is lit To demonstrate human vs. computing reflexes. I'd like to have some kind of external build to demonstrate with as the "vs.".
I am thinking I can use a laser and point it at the LED block because lasers are capable of transferring data. I would think it wouldn't be too difficult to make a build that distinguishes between on & off. It's basic binary, on & off 1 & 0, true & false, same & changed. When the surface lights that the laser is pointed on, I think the easiest way to push the button would be to discharge a capacitor into a hobby motor, and some kind of tab or something on the motor. I can go into more detail on the build, but I need more info on making a laser operated trigger system thingy.
Jun 27, 2010. 10:52 AMlemonie says:
Well your easiest way is to plug the computer into the matrix (but that would be a "duh?" type of thing)
You could probably do it with a video camera and the right software.
L
Jun 27, 2010. 4:20 PMsteveastrouk says:
Thing is, detecting a laser spot, through a glass window, and in an exhibition light is NOT trivially easy. You still haven't said how long you have to do this in.
You could trigger "Player" by using your laser to hit an invisible target in the case, it switches to player mode until no-one shoots the game for 20 seconds or so, then it reverts back to demo. Steve
Jun 27, 2010. 11:23 PMsteveastrouk says:
An actual build is going to be a bit implausible...
Yes, I think its a bit too ambitious, and image recognition even more so.
Steve
Jun 27, 2010. 1:33 PMsteveastrouk says:
So, you want to shoot the led block with the laser and identify the shot block ?
Jun 27, 2010. 2:26 PMsteveastrouk says:
You need a laser you can modulate an audio tone into. What colour are your LEDs ? If the laser is strongly the same colour, the LED makes a pretty good detector, with the right electronics around it, even when its lit. Failing that, you could sneak plastic optical fibres between the LEDS and onto some photodiodes. How long have you got to do this crazy thing in ? Steve
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
