3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Is it possible to make a 9v adapter, or any adapter for that matter, wireless?
As in not needing to plug it into a wall.
Feb 1, 2009. 11:30 AMUziMonkey says:
Yes. I do something similar for a breadboard power supply. Get a 12v nicad battery pack like they put in RC cars. These things can store lots of charge and can draw pretty high current. Hook up a voltage regulator to keep it regulated at 9v, and add in a cord with the correct barrel jack to plug into whatever you're powering. You may be able to just use a 9v battery, but depending on the device you're powering, it may drain the battery too quickly. The battery packs with a regulator will last a lot longer, can be recharged, but are larger.
Mar 6, 2009. 8:02 AMGrand-Pa says:
ya! It's called a battery
Feb 1, 2009. 2:50 PMalex-sharetskiy says:
@ UziMonkey you don't really need a voltage regulator
Feb 1, 2009. 10:40 AMjeoncs says:
Should just be a matter of finding a spot to wire in a 9v battery connector
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
