loading
Is it possible to make a LED blinking circuit with a single transistor?
qs8 years ago
It's simpler than you think - one transistor and one "AA" battery. Check it out here.
qs
Rmcfarland8 years ago
Actually, it is possible. See this website. I have built this circuit and can verify that it does work, but I had much better success using 2N2222 transistors. Also, you need around 12 volts for it to work properly. Hope this helps!
UziMonkey8 years ago
You'll need a little more than a transistor. You need some kind of timer (usually controlled by a capacitor and resistor) and a flip-flop or similar. This circuit is about as simple as you can get, and is controlled by the charging and discharging of the capacitor. Though a 555 IC is easier to use and is dirt cheap.
