Is it possible to make a plane that can hover (helicopter style) in the air using three downward facing turbofans?
Would it be possible to make a plane that can hover (helicopter style) in the air using three turbo fans or turboprops (two big ones on the sides to lift the aircraft and one on the back to steer) I was just wondering if that would be possible, not that i even have the tools to try it out. I just have a hobby of speculating about these things. If it would really be tried in the near future, it would be a great alternative to an attack helicopter! See this link for a good example how it would be like: http://cnc.wikia.com/wiki/ORCA_Assault_Craft . Please do not take this question to seriously, I am just an ordinary knexer and so i'm not going to do anything with this. But I was just wondering...
Attack helicopters are just fine as they are, the blade system works well for hovering. Balance is a key tricky-area for vectored thrust aircraft. (Other comments noted)
You're not going to get your hands on turbofan engines are you?! Good designs (e.g. Harrier) have already been realised. The Moller SkyCar sounds like what you are thinking of, you could look for more information on that?
yes it is possible... i know its do able because im busy building a r/c model, its just very expensive. you might want to chek out tricopters and take a look at the f-35 lightning real life vtol fighter jet... also search on youtube for vtol rc aircraft there are some pretty neat designs...
. The Harrier uses thrust vectoring in a similar fashion. . Googling "articulated jet engines" turns up some interesting stuff more along the lines of the ORCA.
The harrier can't hover like this for long; what I meant was more like chopper style. The search for articulated jet engines on google did not yield any results.
It is possible but you would have to have enough thrust to carry every thing. They have made planes similar such as the Hawker Siddeley. They are called VTOL or vertical take off and landing. The Hawker Siddeley is in the family off the Harrier. They are also called jump jets.
Bio:This part used to be full of crap but I deleted most of it... most of it. ;-)
Greetings, fellow instructabler. I'm Tigernod. I'm a student from North Brabant. I am a fanatic player of panna soccer (i...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
choppers
L
L
