Is it possible to make a side arm firing green rods with slide and removable mag ?
i have searched the whole Internet but didn't find something useful... And of course it has to work :-)
knex_mepalm8 years ago
sure, but i will be very weak because of the bulkiness and the rods comig from an outside source, and the slide mush be weak or the ram is too hard to pull back, not worth the build.
An Villain8 years ago
you can mod the ZHG to have a slide, it has clips, fires green rods, and may use a slide if modded right.
Yes it would be possible. Though I fear that it would be very unreliable and weak. I also don't know how to put a slide on a knex gun (except for the tube and stick concept with many connectors onto a rod.)
TheDunkis8 years ago
No one actually brought forth a design? Well I could try something later but I'm busy redoing my shot pistol and working on an oodammo pistol at the moment.
DARKCOBRA8 years ago
Yes, there is a sidearm that has a slide and a removable mag but shoots dark gray connectors with green rods connected made by ironman69
TigerNod8 years ago
Yes. If a normal gun can do that, a sidearm will do too.
King_Banana8 years ago
put a slide on the SKP an there you go
devenda (author)  King_Banana8 years ago
Thanks but do you have a link?
ajleece8 years ago
YES i will make one for you once i have finished my latest ible
devenda (author)  ajleece8 years ago
Thanks!!
I did try to make several but none of them worked it just couldn't feed green rod out of a 'clip' in to the slider.
and it didn't look very 'realistic' :p
Thanks!!
(just tell me if its ready )
Yeah. Talk to TheDunkis.
